Newbie here! question on door locks and window
Old Apr 4, 2011 | 12:01 PM
Tinklespout's Avatar
Tinklespout
Hi, I'm new here and still figuring things out. I'm quite handy so some suggestions would be nice.
1) My driver side door won't open with the remote but opens OK with the key.
2) The driver side window sometimes doesn't work so I keep a rubber mallet under the seat which corrects it every time. I know this is bad but it's a small mallet.
Thanks a bunch. Kim
Old Apr 4, 2011 | 12:43 PM
Kymini's Avatar
Kymini
I have the same problem with the driver side door. Mine will lock with the key fob as well as the central locking system, just won't unlock with the key fob. It sounds like it is doing something but nothing happens. I have not pulled the actuator out yet but suspect that it might be the problem. I would like to know if you get yours fixed and what the problem was. Thanks!
Old Apr 8, 2011 | 10:49 AM
Tinklespout
Same problem
Yes, exactly the same symptoms. I hope someone gets back to us with some suggestions.
Old Apr 8, 2011 | 12:41 PM
cristo's Avatar
cristo
Alliance Member
Thanks a bunch. Kim
1 - sounds like the actuator - see this thread (it's a long one):
https://www.northamericanmotoring.co...-problems.html
2 - sounds like the window motor - replacing or even cleaning the brushes
on the motor should help, but might want to rely on the mallet for a while first.
I think there's a thread for the window motor as well.
Yep, here it is:
https://www.northamericanmotoring.co...-fix-free.html
Sounds like the actuator, but only one of the two solenoids has gone south.
Dec 23, 2015 10:36 AM
coachvminis
Aug 17, 2015 01:42 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
