Power Steering fan fuse
Old Mar 2, 2011 | 03:36 PM
Herleman's Avatar
Herleman
Where is it? Got a new fan on our daughter's 2005 Justa. It does not run. Thought the fuse was the most likely culprit but the diagrams do not identify it or its location.
Thanks folks.
Old Mar 30, 2011 | 07:35 AM
rhcp4life's Avatar
rhcp4life
Could be your low speed fan resistor do a search
Old Mar 30, 2011 | 07:57 AM
ZippyNH's Avatar
ZippyNH
The ps fan only runs in SOME cirmstancances....
The fact is does not always/obviously run may not indicate an issue...
The fan should run if the AC is on or the radiator fan is running on HI ( I think).
Check to see if you actually have an issue before thinking you have a bigger issue...
Many folks on thee boards have "found issues" that they think they have as budding auto trouble repairmen....costing $$ and time to "fix" when things are ok.
Just be certain you have an issue before spending more $$.
Old Mar 30, 2011 | 08:03 AM
ZippyNH's Avatar
ZippyNH
PS
the fuse on my 2005 S
Modified by the dealer (in was built late 2004 as a 2005) is in the interior fuse pane..a 5 amp fuse I think....all 2005+ productionshould be set up the same. Rear most row, botto fuse plugged in I think.
Old Mar 30, 2011 | 02:09 PM
Cadenza's Avatar
Cadenza
Thanks folks.
The fuse for the PS fan is located in the engine compartment, the box next to the strut tower. It's F08 (30 amps) or 3rd fuse on the left row. This fuse is also used for the Heating & AC blower. So if your blower works, the fuse is good.
The PS fan relay might be faulty if the fuse is good. The PS fan relay is located behind the left kick panel (driver's foot-well). Remove the cover, the fuse panel and turn it over. According to the Bentley manual, the relay is K69923.
Old Mar 30, 2011 | 03:03 PM
ZippyNH's Avatar
ZippyNH
On 2005 cars, or any car modified by mini to fix the ps fan blowing the radiator fan problem, the fuse is in the car...
My 2004 production, 2005 year was delevered with the old harness, then "updated" to the 2005 build standard by my forward thinking proactive dealer...
With the old wiring ...2004 and earlier/unmodifed, the fan ps fan could jam, causing the radiator fan to stop when the fuse blew...it shared a fuse...causing the car to overheat quickly without motion or in hot weather.
With the mod/newer cars, the ps fan and the back-up warning ( if installed) usually shares a fuse....
Old Mar 30, 2011 | 06:36 PM
rhcp4life's Avatar
rhcp4life
http://www.bmw-planet.com/diagrams/release/en/index.htm
Good website for mini wiring diagrams
Manny_cooper
Sep 10, 2015 11:09 AM
HaveATank
Sep 4, 2015 08:04 AM
Aug 25, 2015 09:33 AM
HaveATank
Aug 24, 2015 10:26 AM
minipopkart
Aug 13, 2015 05:22 AM
