Knock Sensor Service Engine Soon Code - Some Questions
Old Feb 14, 2011 | 02:01 PM
blacter's Avatar
blacter
I just had the head replaced on my '02 Cooper and had the "Service Engine Soon" light come on on my first highway trip. Turned out it was P0326 "Knock Sensor 1 Circuit Range/Performance." A couple of questions for you mechanically inclined folk:
1. Does anything come to mind in replacing the head that could have led to the knock sensor issue?
2. Looks like the knock sensor itself is not an expensive part. How hard is it to replace? Have any of you run across a how-to?
Thanks.
Old Feb 14, 2011 | 03:31 PM
HRM's Avatar
HRM
I would check the wire is connected still. Maybe it wiggled loose.
Old Feb 14, 2011 | 04:04 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
yeah, knock sensor going out is a rare occurance......like seeing a unicorn.
They probably just forgot to plug it in or push the connector home and secure it.
Old Feb 14, 2011 | 05:34 PM
Revolution Mini Works's Avatar
I would "normally" agree, I've seen 2 bad knock sensors now in the last 2mo., this will be the 3rd........
Old Feb 14, 2011 | 05:47 PM
blacter's Avatar
blacter
Thanks, all. Where is the sensor located in my R50?
Old Feb 14, 2011 | 08:50 PM
on the front of the block just below the intake manifold ports
center of block
Old Feb 16, 2011 | 01:10 PM
blacter's Avatar
blacter
On my '02, the knock sensor plugs into a connector to the right of the fuel rail, correct? There's nothing plugged in there now, so I assume the mechanic who installed the new head missed this on reassembly. I think I see the wire at the bottom of the intake manifold, but can't pull it up. Looks like the plug is stuck on something. Time for a return trip to the shop.
Kimolaoha
Jul 5, 2023 01:04 PM
09R56
Nov 16, 2022 10:49 AM
silence2-38554
Nov 12, 2015 09:39 AM
PSIChocolate
Aug 13, 2015 12:46 PM
massmini03
Aug 12, 2015 11:19 AM
