Problem with vibrating accelerator pedal in R50
Old Feb 11, 2011 | 03:34 PM
Dan Mini 21's Avatar
Dan Mini 21
Hi all i am stumped with this problem and about to give up..My accelerator pedal does a fine vibration on most roads..When the road gets rougher it seems to vibrate more making me think control arm bushings but i did the Way Mororworks poly urethane bushings so that is not it..I have new Konis all around and the strut tops are fine and not mushrooming so i tried replacing the acc pedal unit itself and that did not do it....Now i am thinking motor mount bushings which is around 500...What is behind that pedal that could make all that vibration..I have a 03 R50 with the CVT trans...If you are the one who solves this i will send you $50.00 OK...Thanks Dan
Svejk
Feb 24, 2019 12:18 PM
maestro39
Oct 27, 2015 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Aug 12, 2015 01:24 PM
