No Power Steering this morning 05 MCS
So I get in the mini this morning an no power steering??? No electric noise??? could it be a fuse? (I hope) Or is it the pump, I had it put away for the winter, but the power steering hose went on my 92 400E winter beater! Now I take the Mini out and NO POWER STEERING AHHHHHHHHH BAD WEEK FOR POWER STEERING. If I drive it will I make it worse?? I did have it on a battery tender maybe it poped the fuse
on
drftobin, did you check the fluid level?
Mine did the same thing - was OK when cold, but troublesome once warmed up. Fluid was low because the pump was leaking. I was able to add fluid and get my steering back, but of course - that didn't fix the leak. Had the pump & hoses replaced, and it's working great now. But it was pricey.
P/S failure is becoming a common thing on these first gen cars.
on
Now be sure to install something to protect the fan.
I have a full skid plate on both of my cars, and on my wife's cooper, there's also the little metal screen over the fan.
Crap gets kicked up from the road and lodged in the fan - then eventually the pump dies from not being cooled by the fan.
on
http://www.mossmini.com/Shop/ViewPro...eIndexID=87847
One note - unless they've changed it, it comes with crappy mounting bolts that use an allen key.
On the advice of a friend, these were replaced with true hex head bolts. And be sure to keep these bolts lubed or use anti-seize.
07-16-2020 12:54 PM
JPMontes3
08-23-2015 01:26 AM
Etrain
14
08-20-2015 10:32 AM
minipopkart
08-13-2015 05:22 AM
