New owner, DSC/tpms lights
Old Jan 25, 2011 | 09:59 AM
YaTuSabe's Avatar
YaTuSabe
Just picked up a 05 MCS with 33k to replace my totaled mkV GTI :( I've owned it for 3 weeks now and I love it so far except the DSC and tpms light are stuck on, DSC toggle doesn't work either, got it scanned and these are the codes
5e16 - CAN TIMEOUT INSTRUMENT CLUSTER
5e5c - RPA PUSH BUTTON ERROR
5e15 - CAN TIMEOUT EGS
5e14 - CAN TIMEOUT DME/DDE
Been reading a lot about possible speed sensor failing or steering angle sensor. Just wanna make sure what it is before I spend money on new sensors. Thanks in advance
Old Jan 26, 2011 | 08:02 AM
YaTuSabe's Avatar
YaTuSabe
anybody?
Old Jan 26, 2011 | 02:48 PM
Mini Mania Info's Avatar
Mini Mania Info
The 05 models didn't come with tpms.
They use a rotational speed sensor at each wheel to detect changes in rotational speed. If the tire goes flat, the diameter changes, thus the speed.
In your case, I suspect one of the rotational speed sensor has gone out. You may be able to clean, re-install to solve the problem - but chances are, you will need to replace one. The challenge is to find which sensor is triggering the problem.
good luck!
Ken
Old Aug 15, 2011 | 12:17 PM
b0rkman's Avatar
b0rkman
Is the rotational wheel sensor the same as the wheel speed sensor? I've got the light trifecta and had the codes read today. The left from wheel sensor foil (5d90) and Timeout EGS (5E15) codes were identified. Thanks for any possible input.
Old Aug 15, 2011 | 12:19 PM
Capt_bj's Avatar
Capt_bj
yes - that's the one . . .
sevin
May 2, 2026 06:11 AM
Getrieben
Sep 12, 2024 07:03 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Zettinger
Aug 25, 2015 04:04 PM
Powershift
Aug 16, 2015 05:14 PM
