Sensors bad?
That's probably a result of one of your wheel speed sensors' malfunctioning... had the exact same issue occur to me. Fairly easily to replace, but I'm not certain of a way to determine which one is going bad since you have one for each wheel. When I replaced mine, I knew my front sensors were having issues since the tri-fecta of lights would only occur when I'd do U-turns.
Here is a link for the sensor in question:
http://www.waymotorworks.com/r50-r53...ed-sensor.html
GotMINI
GotMINI
I am having the same problem. I bought a new front sensor from ebay and was going to just install it on one side and through trial and error, see if that's the faulty one but I cannot get the hub plug end of the sensor out. Anyone figured out how to get it out without breaking the one already in there? Does it just pop in/out?
