Rear Parking Light Bulb Replacement
Old Dec 29, 2010 | 01:34 PM
frances56's Avatar
frances56
This is a pretty stupid question since I have been driving my '03 MC for 7 years, but where exactly are the rear parking lights? the dealer told me all 4 parking bulbs were out so I figured I would save some money and replace them myself.
The owner's manual doesn't show where any of the lights are on the exterior so I did some web searching and figured out how to replace the front ones, thank you @how. But the rear panel has 3 bulbs and is going to be painful to extract so I want to know exactly which bulb needs done before I try it.
Why are there no diagrams of this?
Old Dec 29, 2010 | 08:37 PM
rkw's Avatar
rkw
In an '03, the rear parking light is the bottom bulb in the taillight. Actually it is a dual filament (1157) bulb for both brake and parking. You can reach in through the luggage compartment and release the bulbholder panel that holds all 3 bulbs. Unclip a horizontal tab underneath the wiring harness connector. It might help to disconnect the connector first (probably have to press on a tab to pull it off).
Old Dec 30, 2010 | 11:12 AM
frances56's Avatar
frances56
Locating Parking Light bulbs
Thanks for the info. I just looked at the assessment from the dealer and it says that the 4 Front parking lights are out. I replaced the bulbs in the small round units in the bumper, but where would the other 2 be?
Old Dec 30, 2010 | 11:25 AM
4130's Avatar
4130
Are they possibly referring to the front wheel arch lights too?
Old Dec 30, 2010 | 12:47 PM
frances56's Avatar
frances56
Front Arch Lights
No idea, what are arch lights? I know about headlights and high beams. there is now mention of arch lights in the manual. Is there a annotated diagram of the lights on this car? The only info in the owner's manual shows where the controls inside are, but not where the various lights are on the exterior.
Old Dec 30, 2010 | 09:37 PM
rkw's Avatar
rkw
The arch lights are in the black trim around the wheels. They look like reflectors (orange at front wheels, red at rear wheels), and they light up when parking lights are turned on.
Old Dec 31, 2010 | 11:18 AM
frances56's Avatar
frances56
Front Parking Lights
OK, got that figured out, now is there a way I can replace the bulbs in the front sides of the bumper?
Old Dec 31, 2010 | 12:42 PM
frances56's Avatar
frances56
Well I finally worked it out.
1. Open the bonnet, remove a small screw at the outer edge of the bumper, right above the arch light, it is parallel to the ground.
2. Carefully pull out the bumper edge to make room, remove the two clips holding the plastic light cover prongs in place.
3. Use a screwdriver to pry out the light cover.
4. Twist and pull out the light bulb holder at the top.
5. Replace the bulb and put everything back together!
Alkaidovich
Jan 30, 2021 01:35 AM
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
