Installation help
Old Dec 8, 2010 | 12:04 PM
minimomof3's Avatar
minimomof3
Installation help
My '04 Mini has a passenger side leak from the hydraulic motor mount. I have found the part and am wanting to install it myself. Reading comments of others having this same issue, does anyone have the step-by-step installation guidelines for this?
Old Dec 8, 2010 | 05:00 PM
Jeller's Avatar
Jeller
http://www.billswebspace.com/MCSPull...tTensioner.htm
Its in this install^
Old Dec 8, 2010 | 06:12 PM
JAB 67's Avatar
JAB 67
Understand that if the only thing you're working on is the passenger side motor mount, you do NOT have to lift the motor; you do, however, have to support it from the bottom before you remove the mount and its bracket. I was able to do this without removing the wheel liner. Just support the car on the right front jacking point, remove the front right wheel, put a bottle jack under the oil pan - I spread the load over a short piece of 2x4 -towards the passenger side, and with a long extension on the external Torx you can remove that long bolt. Then remove the bolts that hold the mount bracket to the engine block, and you can figure out the rest. Really pretty easy.
Old Dec 8, 2010 | 07:51 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Jacking up the motor is faster and easier than removing the bracket from the block. Either way works, but at the shop time is money.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
