coolant expansion tank
Old Nov 24, 2010 | 03:33 PM
mknawabi's Avatar
mknawabi
My coolant expansion tank in my 2003 Mini Cooper has a crack in the cap. There doesn't seem to be a crack in the seam of the bottom of the tank, and so I'm wondering if this has anything to do with the fact that I am losing coolant? I'll try and take some photos.
Old Nov 24, 2010 | 03:36 PM
Capt_bj's Avatar
Capt_bj
The GEN1 tank is a piece of **** and I ended up replacing mine, or those of other owners, about every 3 years.
Fortunately is is neither expensive or hard to replace.
If I had a cracked cap I'd replace the whole unit.
Is that where your coolant is going? Hmmmmm ... check the thermostat housing.
Old Nov 24, 2010 | 03:42 PM
mknawabi's Avatar
mknawabi
I've replaced the thermostat housing and gasket a while back because I thought that was what the issue was the first time around.. However, I noticed the coolant is gone again (it's been a couple months now).
Also, sorry for not putting this in the Stock Problems forum, I'm frustrated and can't think!
Old Nov 24, 2010 | 03:52 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Is this a Cooper or an S? They are different. If it's an S the tank is under pressure and it would be a loss of coolant.
If it is a cooper the tank is just an overflow tank and that is not your coolant loss.
Old Nov 24, 2010 | 03:54 PM
mknawabi's Avatar
mknawabi
Okay that helps...
Now what I need to do is figure out how to flush the system and bleed it out. Considering most of the guides I have seen pertain to the S, how would I go about finding out which hoses I need to vacuum?
Thanks again for the help,
Yama
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
OutMotoring
Mar 3, 2017 06:29 AM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
rt808
Sep 25, 2015 01:59 PM
