TPMS Warning Light
Old Nov 10, 2010 | 09:26 PM
05Greenie's Avatar
05Greenie
TPMS Warning Light
So, I changed out my summer tires for my winter set and now the TPMS warning light is iluminated. Neither sets have TPMS sensors, so why would it be illuminated? Will it go off on it's own?
Old Nov 10, 2010 | 09:31 PM
ericfreeman's Avatar
ericfreeman
I believe your system uses the ABS sensors to detect a difference in tire circumference to alert you to a possible deflated tire. You should be able to reset the system with the button under the handbrake, unless the '05 is different from the '04. My owner's manual says to reset the system whenever changing the tire pressure or swapping tires. Could be your system is remembering the previous tires and is recognizing the new ones as a problem.
However, I recently installed new Blizzak LM60's on new wheels and didn't have the warning light come on. Bit confusing.....
Eric
Old Nov 10, 2010 | 09:37 PM
Eric_Rowland's Avatar
Eric_Rowland
Eric's got it. I've had several false positives, once at the track after increasing the tire pressure. Just reset it (IIRC, turn car on, press and hold TPMS button under parking brake, light goes off, motor on.)
Old Nov 11, 2010 | 06:58 AM
smurfette26's Avatar
smurfette26
I think for my TPMS light, you had to press and hold the button for a couple of seconds, then start driving. Light kicked off after a couple of miles. Forgive me if I am wrong, it was months ago and sometimes I cant remember why I walked into a room!
Old Nov 11, 2010 | 07:46 AM
MINIdave's Avatar
MINIdave
Do none of you people have owner's manuals?
Smurfette is right, press and hold, then motor on - the light will reset.
bneer
Jul 15, 2019 04:41 PM
Lschneider
Aug 21, 2015 02:21 AM
one73ronin
Aug 19, 2015 12:36 PM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
