dsc turns back on
dsc turns back on
It was raining very hard one day last week and my dsc was off as I usually keep it, and I lost traction, a bit of excessive throttle, the dsc light went out, got back in shape and then the light turned back on... anyone know what the deal is with this? I can't seem to figure this out.
ok, did it again today, these are the conditions, if I launch and lose traction it turns back on until i'm moving again, then it turns back off and will not assist anymore... maybe is some kind of snow mode or launch control for poor traction conditions that kicks in... but I know it does not turn completely off....... is this the case for anyone else?
It was probably the traction control (ASC) turning on, which operates separately from the DSC. DSC is the system that can operate each brake individually. ASC reduces power when wheel slippage is detected. There was some discussion here: https://www.northamericanmotoring.co...ml#post1360959
Edit: reading through the other thread more carefully, it seems that turning off DSC should also turn off ASC. I'm not sure why it's behaving as it does in your case.
maybe your car just isnt into going slideways?
i would think that shutting down the DSC would aslo shut down the ASC
Hmm, sounds like something is wrong. On my 2006 MCS I always drive with DSC off and it stays off. That includes on the street, in snow, autox and track days and I've never had the DSC come back on by itself except when that wheel speed sensor was bad. Hope you get it sorted out.
Just buy the:
$ 69.95
Ian Cull's Auto-Up V7
The Ian Cull's Auto-Up circuit adds auto-up window, track-mode DSC defeat, and auto front fog-light control to the R50, R52 and R53 Mini Cooper. New in V7 is one-click window control, dual window control and two channels of Stealth Mode Accessory Control.
From custom mini shop.... 559-320-0004
I LOVE this mod!
$ 69.95
I LOVE this mod!
There is only one way to completely defeat DSC on the R53. That is remove the ABS fuse. You will also loose your speedo though. no ABS/speedo or DSC because the ABS module runs the DSC program. Likely you have something wrong electronically. Once the DSC is turned off, it is off. only a very basic monitoring system stays on when this is off. Even in a wild crazy event the DSC should not turn itself on then off. Possible fault that corrects itself (loose connection hint hint) or failing sensor can cause these types of conditions to occur.
Good luck with the hunt.
and months later the problem continues, seems that the wet is the only factor that affects anything, looks like ive got a loose connection somewhere, hopefully I dont have to buy all new sensors :(
different question, is there a way to completely disable ABS pump so it stops interfering, without losing speedo funcions?
I don't mind lights galore on my dash as this can be easily fixed wiht some electrical tape
but i would hate to lose the speedo and subsequently gas gauge from what I've noticed after pulling the fuse. If i disconnect the pump by unplugging the harness, I get the same thing as the master ABS fuse pull but as mentioned above it's not desireable due to the speedo issue.
09R56
Nov 16, 2022 10:49 AM
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
Oct 24, 2018 01:20 AM
tylewis
Aug 18, 2015 06:53 AM
. Could of just been a fluke if anything.
