Bleeding Coolant lines Help
Old Oct 11, 2010 | 10:39 AM
danmx's Avatar
danmx
Hey guys
I recently asked for help on how to replace my thermostat and thermostat housing, well finally i got around to finish it (which im very proud of for my first under the hood experience) However I got to the last step in which I am asked to leave the air bleed screw open until some of the coolant seeps out. I did this however it will not seep out any coolant, I got to the point where the temperature gauge was getting to the really hot section again so I turned it off being scared of my engine over heating. Any ideas on what I should do next? I have spoken to some people that tell me i am done, and others that tell me to keep it running regardless of the temperature heating up
I think the coolant is flowing since when i touch the hoses they feel warm/hot
Old Oct 11, 2010 | 04:46 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Should work
Start the engine and put the heat on.
Loosen the bleeder valve some until you hear some air release. Release the air then tighten it back up. Check the coolant tank level and top it off with more antifreeze mixture.
Keep repeating this process until the point that when you loosen the bleeder valve, no more air comes out, just coolant.
At this point check the coolant tank again, system should be about full. Keep your eye on the coolant temps in case there happens to be more air pockets. Check for leaks and then rinse off excess coolant spilled into the engine bay.
Old Oct 11, 2010 | 05:46 PM
Fatherdeth's Avatar
Fatherdeth
Everything Raven said. Also, just know it takes a while, so be patient and you'll get it.
Old Feb 20, 2011 | 04:21 PM
Checkmate_2006's Avatar
Checkmate_2006
where is the coolant bleeder valve?
Old Feb 20, 2011 | 06:29 PM
Eric_Rowland's Avatar
Eric_Rowland
It's right in front of the radiator, just to the left of center. There is a a plastic insert in the rubber hose that has a round screw with a flat top and two perpendicular slots that will fit a large flat blade screwdriver.
Old Feb 20, 2011 | 08:19 PM
Checkmate_2006
thanks Eric. When we cut the lines in the tubing to add the adapter for the water temp sensor I know some air must have been introduced to the system. I will bleed the lines tomorrow. I have been working on the car all weekend installing the GP IC, JCW CAI, oil pressure and water temp gauges. All this while fighting a cold. my priorities are clear.
Old Feb 23, 2011 | 03:15 PM
Checkmate_2006
Do I release the vavle until violent comes out or just loosen and tighten until coolant comes out?
Old Feb 24, 2011 | 10:24 AM
Eric_Rowland
'violent'??
It will usually sputter a bit with air and coolant. Just wait until only coolant comes out, then tighten. And wash down the spilled coolant.
Old Feb 24, 2011 | 01:05 PM
HRM's Avatar
HRM
Start with the engine cold, not hot or it will be violent.
sempaipaul
Oct 26, 2015 05:56 PM
debitsandcredits
Sep 21, 2015 08:34 AM
makg
Sep 10, 2015 11:59 AM
mimaal
Sep 4, 2015 09:09 AM
