Battery cable squib resistance
Old Jan 23, 2017 | 04:51 PM
  #26
Mini_Chan's Avatar
Mini_Chan
That would be awesome. If you can't find it, i'll just use a piece of electric tape so I won't have to see that stupid light ever again.
Old Jan 24, 2017 | 06:05 PM
  #27
Mini_Chan's Avatar
Mini_Chan
Can we use a 3.3 ohm 5 watt resistor or does it have to be 3.2?
Old Jan 25, 2017 | 06:01 PM
  #28
coopspeed's Avatar
coopspeed
3.3 is good. In fact that's what I have if you want it.
It's a 3.3 ohm 5 watt. It's what I used.
Pm me your address and I will mail it.
Coop
Old Jan 25, 2017 | 07:15 PM
  #29
Mini_Chan's Avatar
Mini_Chan
pm sent! thanks again
Old May 14, 2019 | 07:18 AM
  #30
Fische18's Avatar
Fische18
Battery Safety Terminal BST is another name for the squib. I have searched all over and was about to give up until I found this thread. I wanted to post the BST so it would be easier for people to find.
I have a 2006 S that I am doing this fix to as soon as I get a resistor from Amazon delivered.
Old May 14, 2019 | 11:51 PM
  #31
coopspeed's Avatar
coopspeed
My Minis are long gone but glad to see the info is still helping!
Old Apr 14, 2020 | 09:52 AM
  #32
Webhead68's Avatar
Webhead68
I’m planning on doing this modification this week. It beats the cost and labor of a new cable which the dealership wanted $1200 to do the job. I just need to get a code reader that will reset the code. The current one i have does not reset SRS codes.
Old Apr 21, 2020 | 09:39 PM
  #33
ken o's Avatar
ken o
Thanks for the thread, trying to fix my daughter's MINI. Where can I find the resistor?
Old Nov 25, 2020 | 01:35 PM
  #34
fri2k11's Avatar
fri2k11
I found the resistor at this
amazon link amazon link
Old Feb 14, 2021 | 06:16 AM
  #35
Bear's Avatar
Bear
It worked!
I just completed this repair and it worked perfectly. I have several of these resistors if anyone needs one.
Old Feb 14, 2021 | 12:49 PM
  #36
tattman23
PM sent.
Old Aug 26, 2022 | 05:14 PM
  #37
redcode9's Avatar
redcode9
Hi guys, I am exhuming this thread because my Mini has such a problem (I already bought it this way). My current situation is as pictured, what can I do to solve the problem economically?
As you can see, I don't have a little piece..
Old Aug 26, 2022 | 05:29 PM
  #38
fri2k11's Avatar
fri2k11
What does that wire that is connected to the positive terminal go to? You will want to find the piece that plugs into the box (referenced in post #19) and close the circuit with the resistor. Plug it back in, then clear the SRS code.
Old Aug 26, 2022 | 05:36 PM
  #39
redcode9's Avatar
redcode9
Thank you for the answer, but "the piece plugs into box #19" , where I can find it? Somewhere I think I read that the bmw E39 repair kit for the BST might be good for our Minis, could I look for that? Or alternatively what should I do in your opinion?
Old Aug 26, 2022 | 08:12 PM
  #40
fri2k11's Avatar
fri2k11
Junkyard is probably your best bet. Not sure about the E39 repair kit.
Old Sep 1, 2022 | 07:15 AM
  #41
Here2Go's Avatar
Here2Go
NAM Community Team
+1m
I preformed the airbag light/squib with the resistor hack as described; 2wo years ago. Works wonderfully. Didn't even have to plug in my OBDII to clear/ extinguish the light. It immediately went out by itself. Light comes on at ignition turns off after seatbelt is engaged
Old Aug 8, 2023 | 07:20 AM
  #42
Savage1007's Avatar
Savage1007
Originally Posted by coopspeed
The resistor is under the black shrink wrap in the photo.
remove the 2 wires that go into the yellow cap on the battery terminal. Those are the ones that fire the squib.
Place the resistor across the 2 wires.
Reset SRS computer.
Good as new.
Good luck
To clarify for myself, the battery squib is to be completely removed from the positive terminal off the battery cable end? Once the resistor is in place how does the system receive its power to activate? I guess I am unfamiliar as to what exactly this wire harness does and how it works...
Old Aug 9, 2023 | 05:46 PM
  #43
Here2Go's Avatar
Here2Go
NAM Community Team
It's been a couple of years since I performed this fix.
Forgive me if I seem unclear...
To answer your question
No - the BST (squb) should stay in place connected to the positive battery terminal as is. Yes you can undo the main positive cable if it makes it easier to access / perform the fix.
Just trace the small black lead that has a connector that plugs into the BST. Within that lead there are two small (or one? - I don't remember) wires sheathed within that lead.
Simply connect each end of your 3.5ohm resister to each ends of those wires as shown in post #19. to complete the circuit. Be sure to plug that wire back into the BST after your done if you removed it to solder the resistor.
Here is another link with pictures that might help if you haven't see it.
Hope this helps.
Old Jan 7, 2024 | 10:58 AM
  #44
ewgoforth's Avatar
ewgoforth
Hope this helps.
Hi,
I did the squib modification and reset my light my creator c310+. Everything seemed OK but my battery died overnight. I also set my interior light so it would come on with the door, so hopefully that did it. Here's a closeup of my repair
I thought it would also work to use the end the positive battery cable and disconnect the squib line from a junked car. It looks like I could crimp it to the end of my battery cable. Maybe with something like this. https://www.zoro.com/grote-battery-splice-2-awg-tin-pk10-84-9553/i/G1295813/?recommended=true
Does anyone know what guage wire this would be?
stuspencer
May 16, 2026 11:29 AM
devenh
Jul 9, 2017 04:37 PM
oneredcooper
Sep 16, 2013 12:42 PM
landev
Apr 24, 2009 06:33 PM
pureinsanity
Electrical
Feb 19, 2007 10:20 AM
