Warning light question...???
Old Jun 3, 2010 | 01:50 PM
Gunny69's Avatar
Gunny69
Today I noticed that my ABS, TCS and TPS lights were on. I turned car off and did a restart... Problem went away for a bit and then the lights came back on and would not go back out. I noticed this happen a week or so ago and then it went away until today. The toggle cluster is loose. I was thinking of pulling it and reseting the connection to the TCS switch.. 05 Justa. 78k.. I did just have new tires put on.... ???
I do not really want to take it in if this is a easy fix. My roads up here are full of pot holes and I live on a dirt road witch is pretty ruff. I am simply hoping something is loose.....
Any thoughts.
Thanks.
Bill
Old Jun 3, 2010 | 01:51 PM
Gunny69's Avatar
Gunny69
Any thoughts.
Thanks.
Bill
Old Jun 3, 2010 | 02:22 PM
ZippyNH's Avatar
ZippyNH
All 3 of those lights beaing on would be consistant with a bad wheel speed sensor...they all use the info from the sensor to determine various things based upon the number of tire rotations verses the other tires.
Old Jun 3, 2010 | 06:11 PM
moreorless's Avatar
moreorless
When the battery starts to fail, it does weird things to our cars. How old is your battery?
Old Jun 3, 2010 | 06:53 PM
minintrigue's Avatar
minintrigue
or could be a wheel speed sensor. if you do a search, there is a thread about the light "trifecta."
Old Jun 3, 2010 | 07:05 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
When the ABS sensor was wet from snow or rain, I had the trifecta of lights on my MCS. It would reset and go out after being parked for a while. Then 100 down the road, lights came on again.
Could have a check to see if there are any codes stored.
Old Jun 3, 2010 | 08:09 PM
Gunny69's Avatar
Gunny69
Thanks...
HHMMM wheel speed sensor makes sense... Tires just changed... Battery,,, I have no clue... She has the sport set up... Roads up here are beating her up... Thanks...
bneer
Jul 15, 2019 04:41 PM
Lschneider
Aug 21, 2015 02:21 AM
one73ronin
Aug 19, 2015 12:36 PM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
