Climate control problems
Old May 18, 2010 | 07:22 PM
jrdoogs's Avatar
jrdoogs
I just had to have the alternator repaired on my 2003 Mini Cooper S and now the computer display is messed up. The mechanic does not know what to do. The outside temp. displays as -40% when the actual temp. outside is 90%. When I set my climate control to 60% it blows out hot because it thinks it is -40. Can anyone help with this problem?
Old May 18, 2010 | 08:28 PM
Suzanne's Chili Red S's Avatar
Sounds like a problem with the outside temp sensor located behind the front bumper. The reading will default to -40 if there is a problem with this sensor.
Old May 19, 2010 | 07:36 AM
jrdoogs's Avatar
jrdoogs
Thank you for the reply. I started my car up this morning and it seems to have reset - the reading was 83 which is correct for FL at 8 am believe it or not! We are in for a hot summer again! I have a problem with the hatch open light on the dash now and all of my doors are closed. Any suggestions?
eatsleepautox
Oct 30, 2015 06:46 AM
kyungmanpark
Aug 23, 2015 07:26 PM
ludedude
Aug 10, 2015 07:16 PM
2manyhobbies
Aug 9, 2015 06:02 PM
