Recurring Engine Carbon Buildup Problem
Old Sep 29, 2010 | 07:26 PM
  #126
KevinC's Avatar
KevinC
Originally Posted by timfitz63
Aside from the obvious (a fuel additive sold by BMW), exactly what is "BMW fuel treatment," and how does it differ from other fuel system cleaners like Techron...?
It IS Techron. BMW's stuff is simply rebranded Techron, just like you'd buy from Chevron. And it will be equally ineffective in this application.
Old Sep 29, 2010 | 07:32 PM
  #127
smackboy1's Avatar
smackboy1
Originally Posted by mstaigle
Just to let everyone know the service tech is recommending the BMW fuel treatment every 3,000 miles. He said this would take care of any build up of the carbon in the fuel system.
As others already pointed out, fuel treatment alone isn't going to help much because fresh fuel doesn't reach the back side of the intake valves (except for the small amount which may escape out the cylinder). What you may need is a cleaning solvent introduced through the air intake system e.g. BG Products air induction service (search on Youtube for video).
If your CEL is lit, it's way beyond anything that a bottle of fuel treatment alone is going to solve. From first hand experience, the carbon coke on the valves is very tough to remove even after soaking in solvent and wire brushing. I would venture to guess that this is probably beyond Techron or Seafoam or any other DIY fix.
FWIW my dealer recommends an air intake carbon cleaning service every 10,000 miles. They use MOC Products and charge $600.
  #128
MotorMouth's Avatar
MotorMouth
Maybe you could pour the techron in the hose like the seafoam. lol
(i am not recommending someone try this)
Old Sep 29, 2010 | 08:15 PM
  #129
Rixter's Avatar
Rixter
So for somebody like me who doesn't know their way around an engine well, how would I know if I need a carbon cleaning service and how would I even know if the work was done properly?
Old Sep 30, 2010 | 08:53 AM
  #130
///Mflossin's Avatar
///Mflossin
Are you serious?
Old Sep 30, 2010 | 09:08 AM
  #131
Dwight Walhood's Avatar
Dwight Walhood
Originally Posted by fishbert
No.
WRONG!! All MINI engines are DFI.
Old Sep 30, 2010 | 02:49 PM
  #132
fishbert's Avatar
fishbert
Are the 2010 Base Cooper engines direct injected?
No.
From http://en.wikipedia.org/wiki/Prince_engine#1.6 ...
"The 1.6 L engine is used in the second-generation Mini and various Peugeot 207 models. ... The naturally-aspirated variant (EP6) has conventional fuel injection ... The turbocharged 1.6 L unit adds gasoline direct injection ... "
Also, http://www.motoringfile.com/2006/07/...icial-preview/ speaks of direct injection on the 2nd generation MINIs only in the context of the turbocharged S.
I don't have a 'justa' in the driveway to go and look at, but I think you'll find that it does not have an engine with direct fuel injection.
Old Sep 30, 2010 | 05:18 PM
  #133
ThumperMCS's Avatar
ThumperMCS
Dwight, Coopers do not have DI...
Old Sep 30, 2010 | 05:27 PM
  #134
Dwight Walhood
OK, I surrender! Looked at the RealOem intake manifold diagrams and saw no injector fittings. Where are they, inside the head itself?
Old Sep 30, 2010 | 06:01 PM
  #135
Octane's Avatar
Octane
Has anyone tried any of the other products like Seafoam and thought it was as good or better than Seafoam for the carbon build up problem ?
Has anyone tried the BG product ISC and if so what did you think of the results ?
Old Sep 30, 2010 | 07:55 PM
  #136
sequence's Avatar
sequence
re Seafoam read the thread and you may discover something I am also not convinced the b/u it is as widespread as posters make it out to be. Out here in CO I know a few people with 2G MCSs approaching 50K and they've had no buildup or coking issues with their engines, so.... ?
Old Sep 30, 2010 | 07:56 PM
  #137
sequence's Avatar
sequence
ah such a bold response. check yr. facts first, sir.
Old Sep 30, 2010 | 07:59 PM
  #138
Dwight Walhood
Read my admission and then make your comment!
Old Oct 1, 2010 | 01:07 AM
  #139
fishbert's Avatar
fishbert
Hey, let's keep it friendly in here, guys.
Old Oct 1, 2010 | 01:45 AM
  #140
Octane's Avatar
Octane
Hey, Sequence
I needed to edit and add to my question in post #135 to get it right. I have use Seafoam on my 2009 factory JCW and my inqury should have read as below.
Has anyone tried ANY OTHER of the products like Seafoam and thought it was as good or better than Seafoam for the carbon build up problem ?
Old Oct 1, 2010 | 04:20 AM
  #141
czar's Avatar
czar
Has anybody considered installing water or water/meth injection!
This will clean your excessive carbon build up, and prevent it from reocurring, as well as give you a performance gain too.
I have it installed, however my installation was/is not to prevent this, this is just 1 of the benefits of installing water/meth injection.
Old Oct 1, 2010 | 02:45 PM
  #142
Octane's Avatar
Octane
Czar,
Yes, I have been considering water/meth injection for a while but I want to take one of the off the shelf units for a R56 and modify it to be a complete quick disconnect unit so when going to the dealer for any warranty work the kit could be quickly uninstalled and warranty work would not be denied because of a meth kit.
I agree that adding a meth injection kit would add all the benifits you mention but has anyone taken their Mini in for warranty work with a meth kit installed and if so what was the dealer's response?
BTW which water/meth kit did you install and is it boost or injector duty cycle controled also did you notice performance gains by just adding kit or did performance gains require a tune for the kit.
Old Oct 1, 2010 | 04:12 PM
  #143
czar's Avatar
czar
My Aquamist water/meth installation works in relation with the fuel demand, this gives greater control, rather than relying on boost demand.
My car has been in for warranty work, I just leave it in place, if I think they may have an issue, dependant on the warranty work to be carried out (engine related) then I would simply remove it and re-fit as necessary.
The initial fitting of my system gave me instant gain, as the ECU is so self adaptive, however I did have a tune for my particular application with very good results,
Old Oct 1, 2010 | 10:49 PM
  #144
ThumperMCS's Avatar
ThumperMCS
I should be running meth soon too...Aquamist as well, best that's out there
Bye bye carbon. Hello horsepower.
Old Oct 2, 2010 | 02:27 AM
  #145
czar's Avatar
czar
Good news Thumper, will you just be spraying into the air intake flow post intercooler?
Old Oct 2, 2010 | 02:46 AM
  #146
ThumperMCS's Avatar
ThumperMCS
I would think to start off with.
But I know they have a special nozzle to spray pre-turbo as well which is supposed to work well. Would be interesting to be spraying in both locations
Old Oct 2, 2010 | 03:02 AM
  #147
czar's Avatar
czar
Do it pre turbo too, huge benefits!
I spray pre turbo, as well as post intercooler and I'm experimenting injecting into each individual intake runner on the manifold, (good to have a spare one!)
And this may surprise quite a few, I have also removed my intercooler, as the intercooler was heating the air flow, after being cooled pre intercooler!
Old Oct 2, 2010 | 10:32 AM
  #148
fishbert's Avatar
fishbert
there was lengthy discussion in another thread regarding water/meth and carbon buildup mitigation. if I remember correctly, the discussion settled on that it would do very little to help with the carbon buildup issue.
I'm on a phone right now, so looking it up is difficult, but when I get back to a real computer I'll see if I can find that thread.
Old Oct 2, 2010 | 10:51 AM
  #149
czar's Avatar
czar
Trust me it really works, your injecting into the air flow stream, and where will the atomized mix end up..........oh yes in the intake track and subsequently the back of the valves, and where is the recurring carbon build up..........oh yes, the back of the valves!
Now when injecting water or a water/meth mix into the air flow, besides the cooling ability, the mix also absorbs the heat and inturn becomes steam, and steam has a dramatic effect on the carbon, by softening and dissolving!
And once gone never will it return whilst injecting water or a mix of water/meth into the air flow stream, period.
Old Oct 2, 2010 | 11:10 AM
  #150
fishbert's Avatar
fishbert
I don't know enough about it to argue one way or another, so I'll have to dig up that other thread where more knowledgeable people than I were explaining why it wouldnt do much for intake valve carbon.
I don't have a dog in this fight; I just recall it being discussed at length previously and that the discussion seemed to end on the 'con' position.
