Outside temp says -40F......I think it's a little warmer than that.
Old May 3, 2010 | 12:11 PM
benjam83's Avatar
benjam83
Before I get too far into it, the car just had the head rebuilt, which surprisingly, required the front end to be removed from the car.
Ok, so to me, -40F says the system is maxed out. So it's either a short to ground or has a constant 12V applied to it. My guess is it's shorted to ground, like a wire is pinched or something like a loose connector.
My guess is that the sensor is located behind the front bumper. Can anyone give me a little further guidance than that?
Danke
Old May 3, 2010 | 12:46 PM
Eric_Rowland's Avatar
Eric_Rowland
It is indeed in the front bumper (left side, IIRC). As I recall, the -40 occurs when the wire is not plugged in to the sensor. Can't remember if you have to remove the bumper to connect it.
PsychoRallye
21
Feb 17, 2019 06:08 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
navybsn
Oct 4, 2015 03:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
