Blown Clutch Question
Old Feb 6, 2010 | 06:17 PM
TheFreakinPope's Avatar
TheFreakinPope
my 03 mini recently blew its clutch and i was told that i am going to need a new clutch and possibly a new flywheel. i was wondering what kind of flywheel my car has, does any body know? everything on the car is stock if that helps any.
Old Feb 6, 2010 | 06:58 PM
ZippyNH's Avatar
ZippyNH
Which 03 MINI.......r50 cooper, or the r53 cooper S?
Old Feb 6, 2010 | 10:27 PM
tazio's Avatar
tazio
Type = Dual mass
Manufacturer = Luk
Old Feb 7, 2010 | 06:25 AM
ZippyNH's Avatar
ZippyNH
There are aftermarket dual mass flywheels on the market now according to my local MINI guy....the flywheel is not resurfaceble, and dualmass flywheels can/do fail....so even if it looks good, replacing it is mandatory. Cheaper traditional flywheels are available also, but expect a bit more NVH than you have now from what I have been hearing!
Old Feb 7, 2010 | 06:32 AM
Helix13mini's Avatar
Helix13mini
If it's a Justa (R50), you probably won't need a new flywheel, and unless it's jamming, the dual-mass flywheel of the R53 probably won't need replacing either. You can resurrect the mating surface of the dual-mass with a Scotch-Brite pad and an air whizzer.
Old Feb 7, 2010 | 06:59 AM
ZippyNH's Avatar
ZippyNH
Great to hear that!! it is such an expensive part....I have always heard people say just replace it!!
If the infamous "chewbaccka" sound is not present when you do the clutch...what is the likelyhood it will last for a full second clutch with out it failing?
Old Feb 7, 2010 | 09:24 AM
Helix13mini
You can never predict when Chewey will rear his head, but it's not worth doing a preventative replacement, because your new flywheel is as likeley to jam as your old, un-broken one. I did a clutch and FW recently, where the new one was barking three weeks after replacement. It was a little bit sticky explaining to the customer why thier 500+ dollar FW sharted the bed, but luckily he was understanding.
andrewjg1994
Jan 29, 2021 07:45 PM
eliseo1981
Jan 28, 2021 02:45 PM
Sep 17, 2015 09:27 AM
Camaro108
Aug 25, 2015 02:44 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
