Oil leak
Old Jan 8, 2010 | 08:28 PM
tommyspitfire's Avatar
tommyspitfire
Oil leak
My 03 Cooper has appeared to develop an oil leak. Is there a more common place than another that could be the cause of this?
Old Jan 9, 2010 | 09:24 AM
Yo'sDad's Avatar
Yo'sDad
Have you attempted to look for the source? Where do you see the leak?
YD
Old Jan 9, 2010 | 09:31 AM
JAB 67's Avatar
JAB 67
The valve cover is a common source and fortunately a relatively easy one to fix.
Old Jan 9, 2010 | 09:37 AM
lotsie's Avatar
lotsie
Oil pan gasket , costly to fix at the stealer.
Mark
Old Jan 9, 2010 | 12:19 PM
Yo'sDad's Avatar
Yo'sDad
The crank sensor on the front of the block is a common leaker.
YD
Old Jan 9, 2010 | 04:09 PM
ZippyNH's Avatar
ZippyNH
The podcast WhiteRoofRadio had a discussion on this recently, and there was a full article on Motoringfile.com.
http://www.motoringfile.com/2009/09/...king-your-oil/
Some very good info....
Old Jan 9, 2010 | 04:53 PM
Capt_bj's Avatar
Capt_bj
where????
fluid filled motor mount problems are common . . .
Old Jan 9, 2010 | 08:36 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
On an 03 I'd say it would be either an oil pan gasket, supercharger inlet gasket, or valve cover gasket. Just had an 03 in that had all 3 leaking today.
Old Jan 10, 2010 | 09:46 AM
R53-BRG's Avatar
R53-BRG
Don't forget the oil cooler on the back of the block. I had that, valvecover, and oil pan all leaking at the same time.
Old Jan 10, 2010 | 10:56 PM
MrCooperS's Avatar
MrCooperS
Moderator
It can also be the o-ring on the oil filter housing. I've had 2 leaks with 2 new aftermarket filter o-rings. Their just a bit smaller and it's enough for the oil to seep through and drip down. If you have a car jack, I'd recommend jacking it up, cleaning all spilled oil and changing out the o-ring on the oil filter. That would be a good and cheap solution to start with.
Old May 31, 2010 | 01:24 PM
DMBFan2's Avatar
DMBFan2
Is this the leak your taking about?
I just noticed a leak and looked under my car to identify the source. Is this the SC inlet side?
https://www.northamericanmotoring.co...-oil-leak.html
The picture is from the under side looking forward.
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
