cooper vs cooper s head
Old Oct 25, 2009 | 01:30 PM
pmfranke's Avatar
pmfranke
Are they interchangeable ?
Old Oct 25, 2009 | 08:20 PM
herbie hind's Avatar
herbie hind
i believe the valve sizes are different. at the time of publishing; my bently did not have the specs for the "s" .
Old Oct 25, 2009 | 08:21 PM
herbie hind
i believe also there is a webb head on sale in market place .
Old Oct 25, 2009 | 10:09 PM
pmfranke's Avatar
pmfranke
thanks, i looked for the head and the post was a year old ! I emailed him so we will see if he still has it. I'm in Hawaii too, so shipping is another thing.
Old Oct 25, 2009 | 10:13 PM
IceManMCS's Avatar
IceManMCS
I have a stock head off my 2003 MCS with 70k miles for sale in the marketplace for $250. Why are you looking to replace yours?
Old Oct 25, 2009 | 10:39 PM
pmfranke's Avatar
pmfranke
I have a blown head gasket ,runs great except for the overheating problem so I wondered if the new cooper head I saw on fleebay could just be swaped . Now im thinkin (more power) as usual ,portting ect. on a new head would be easy, cheapish way to get more power since its going to be apart anyway. looking for options.my head has 60k but it is unknown if it is warped or cracked or just the gasket let go. 6 years of racing with a 19% pullie has taken its toll. A used High Power head would be the best option I guess. thanks for the offer of your head.
Old Oct 26, 2009 | 10:22 AM
miniRover38's Avatar
miniRover38
I've inpsected the two side by side and the only difference I could find was that the R53 head has studs for the intake manifold whereas the R50 uses bolts. I didn't take any maeasurements but they looked exactly the same. You would be better off taking your head to a good head specialist and having them completely service it. Machining, cleaning, valve job with new seals, checking for cracks. At the very least have it machined. After all of that then you should think about porting.
No matter which head you choose to install, have it machined at the very least, unless it's new of course.
Old Oct 26, 2009 | 10:46 AM
kenatminimania's Avatar
kenatminimania
Cooper S head vs. Cooper:
Old Oct 26, 2009 | 11:38 AM
pmfranke's Avatar
pmfranke
Thanks , ken and rover that what I wanted to know. They arre not the same but could be interchanged. Peter
Old Oct 26, 2009 | 11:52 AM
Dr Obnxs's Avatar
Dr Obnxs
As far as I know
the only real difference is the exhaust valves. And this is material, not size.
Matt
Old Oct 26, 2009 | 11:59 AM
cristo's Avatar
cristo
Alliance Member
Yep, on realoem, the cylinder heads, cams, valvetrain and tensioner parts all have
identical part numbers except the intake and exhaust valves between the
r50 and r53 (non-jcw).
Old Oct 26, 2009 | 05:00 PM
herbie hind
great article ; seem to be alot more differences than i would've figured . good to know .
Old Oct 26, 2009 | 06:07 PM
cristo's Avatar
cristo
Alliance Member
Here's the original article: http://www.motoringfile.com/files/MCS_Powertrain.pdf
Still doesn't jive with the MC head, cam, springs, retainers, valve seals,
tensioners, rockers, etc. all having the same part # as the MCS version
except for the intake and exhaust valves (same size, different part#).
I looked at 3/2003 build.
Can anyone confirm that there's really any differnce besides the valve material, or was
this early wishful white-paper-ing?
Old Oct 26, 2009 | 09:27 PM
Dr Obnxs's Avatar
Dr Obnxs
I think it was the original spec
but when supply chain issues came up, there was no benefit to keeping it that way.
Matt
bobbiemartin
Jan 20, 2016 05:28 PM
Trevor413WC50
Aug 18, 2015 10:38 AM
MIminiclubman
Aug 5, 2015 09:14 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
