Help again please.... CEL
Old Sep 30, 2009 | 05:51 AM
MIN 18's Avatar
MIN 18
A few weeks ago, I started a thread regarding my CEL. I live in the Philippines and there is no dealership here to support me.
I found a shop that has 2 types of OBD2 scanner. Unfortunately, the scanners were not giving enough information on what to fix. We already changed my spark plugs but still the CEL came back on. Can you guys help me decode the fault code? What should we do to fix it?
SCANNER 1
When they scanned my car using the EQUUS INNOVA 3110, the error that came out was (P2187 system too lean at idle bank 1)
SCANNER 2
When they used another scanner called the bavarian technic, the fault that came out was (2785)
I tried searching the net but I am not good at this type of research. The autoshop told me to research and tell him what I got. Thanks in advance for helping me. The CEL is really frustrating....
Old Sep 30, 2009 | 06:11 AM
MIN 18's Avatar
MIN 18
I forgot to add the information of my car. I have a 2007 MCS manual all stock with 12,500km milage. The check engine light went on around 12,000km
Any leads on what the cause or how to fix would be greatly appreciated. Thanks!
Old Sep 30, 2009 | 06:13 AM
slinger688's Avatar
slinger688
Is it a US or European spec Mini?
Old Sep 30, 2009 | 06:29 AM
MIN 18's Avatar
MIN 18
Hi slinger688, this is a US spec mini. I am just using the km reading on my odometer
Old Sep 30, 2009 | 06:34 AM
slinger688's Avatar
slinger688
Did you do a reset of the CEL? And did it come back on after the reset?
Old Sep 30, 2009 | 06:56 AM
MIN 18's Avatar
MIN 18
1st reset by using the Equus Innova 3110 scanner. CEL came back after 20km
2nd reset again by Equus Innova. CEL came back after 8km
3rd reset using Bavarian software. CEL came back after 80km
4th reset using Bavarian softeare. CEL came back instantly
5th reset using Equus Innova. CEL came back after 8-10 km
I don't know what to do anymore! haha
Old Sep 30, 2009 | 07:23 AM
slinger688's Avatar
slinger688
Question: Are you feeling any loss of power?
Not seeing the car, I will try to help but it is with some guesses. But confirm this before doing any real work.
1. Try replacing the oxygen sensor or putting one of those exhaust bungs to move the oxygen sensor out a little.
2. Check for air leaks
3. Check for exhaust leaks
4. Check to make sure all the connections are good. Push them in and make sure they are tight.
Old Sep 30, 2009 | 07:46 AM
MIN 18's Avatar
MIN 18
Thank You very much for actively replying. I do experience power loss at high speeds.
Before changing plugs(CEL ON), I barely reached 150kph and at 5th and 6th gear, the car can't go past 5k RPM.
After changing plugs(CEL OFF), the car reached 180 kph but seems like it wasn't as easy reaching 180kph as before. Plus the RPM won't touch 6k. On my way home, driving 60kph, CEL turned ON again! :(
As per your advise, since I am an idiot with regards to car maintenance, I will forward your suggestion to my trusted autoshop. I hope they will be able to resolve my problem. Let me know if you have some more insights. I will try to bring the car in to the shop again this Friday.
THANKS!
Old Sep 30, 2009 | 08:02 AM
slinger688's Avatar
slinger688
Min 18,
Why don't you wait for a few more comments and advise before doing something. Perhaps another NAMer has better advise.
Old Sep 30, 2009 | 08:16 AM
MIN 18's Avatar
MIN 18
Min 18,
I will. I have a few more days before I bring the car back to the shop anyway. I hope more people would post their insights with what I'm currently facing.
Old Sep 30, 2009 | 08:17 AM
Oxybluecoop's Avatar
Oxybluecoop
The p2785 code is the "Clutch Actuator Temp Too High"
Possible fault cause for the p2187:
- Incorrect main charge signal
- Intake air system leaking
- Fuel pressure too low
- Volume supply of fuel pump too low
- Mechanical fault in injection valves
- PCV valve leaks
- Cap of oil filler neck leaking
- Leaks in exhaust system
Old Sep 30, 2009 | 07:26 PM
skimmilk's Avatar
skimmilk
I would check the high pressure fuel pump. They seem to crack on the early side.
Old Oct 1, 2009 | 08:29 AM
MIN 18's Avatar
MIN 18
oxybluecoop, Thanks for the extensive list of what to check. I really appreciate this. I will tell my autoshop to check all of those. Thanks again!
skimmilk, I just ordered an new fuel filter. Will tell them to check the fuel pump also THANKS!
Old Dec 28, 2013 | 11:38 AM
hlamin's Avatar
hlamin
Hi everybody.
I have the same errors. P2187 via OBD scanner and 2785 via BMW DIS.
Also i saw that additive and multiplicative correction of O2 sensors are very high (6.8% and 1.08) They start to increese after i reset rhe codes and become to these values after one minute. After additive correction reach 6% the engine fall to safe mode and power loss after 5rpm.
Did anyone fix this issues?
Old Dec 29, 2013 | 01:12 AM
robbo mcs's Avatar
robbo mcs
- PCV valve leaks
Just for clarity he does not have a "p2785" code. The bavarian technic gave the 2785 code, which is not the same as p2785. Bavarian technic reads proprietry BMW codes rather than "p codes".
Old Dec 29, 2013 | 10:37 PM
hlamin's Avatar
hlamin
Yes, you are right.
BMW code 2785 mean "Additive correction too much"
Old Jan 20, 2014 | 05:06 AM
hlamin's Avatar
hlamin
Hi all,
I replaced HPFP yesterday and it didn't fix this issue. Additive correction still increesed too much and error appears again. But multiplicative correction now near the 1.
As you can at the pic below:
Multiplicative it is "множительная", additive it is "суммирующая"
Old Jan 23, 2014 | 12:11 PM
Mini838's Avatar
Mini838
What does the screen shot say in english?
Old Jan 23, 2014 | 01:52 PM
hlamin's Avatar
hlamin
See at bottom form:
Суммирующая коррекция состава смеси 6.56
Множительная коррекция состава рабочей смеси 0.99
Фактическое значение лямбда 1.00
Заданное значения лямбда 1.00
Translate is:
additive correction of O2 sensor 6.56
multiplicative correction of O2 sensor 0.99
actual value of O2 sensor 1.00
desired value of O2 sensor 1.00
It is mean that ECU tried to increase air/fuel(give much fuel) ratio at idle, tried to decrease air/fuel ratio at run(give much air).
neezebeeze
Oct 31, 2016 12:10 PM
rob&JCW
Oct 9, 2015 11:12 AM
potterstein
Oct 2, 2015 09:30 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Nick Royer
Sep 16, 2015 08:17 AM
