Comfort Access issue ...
Old Feb 22, 2019 | 06:48 AM
  #26
Ok, so it still does not work?
Old Feb 22, 2019 | 07:34 AM
  #27
BadBadDonkey's Avatar
BadBadDonkey
It does not work with a new fob battery. Plus car battery was replaced in January. Just makes clicking sounds when door handle button is pressed.
Old Feb 22, 2019 | 07:40 AM
  #28
Did you scan the system with a good scan tool like schwaben, might be the sensors themselves or the CA module.
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
Old Feb 22, 2019 | 07:45 AM
  #29
BadBadDonkey
No I don't have a good scan tool. But thanks
Old Feb 22, 2019 | 07:47 AM
  #30
Ok, yep you are going to have the scan the system for faults related to the CA or door lock section. Just auto scan the whole car and see what comes up. This tool is not like others, its for MINI and finds all those weird internal codes like the dealership would find.
Old Mar 20, 2022 | 05:42 PM
  #31
UkJcw's Avatar
UkJcw
hello I have a question I have a mini Jcw 2013 it is not equipped with comfort access I absolutely want to install it because my old one was equipped! do I absolutely have to change the complete interior wire duvet to equip it with comfort access or the terminals are already ready to add antenna modules
Old Mar 20, 2022 | 05:58 PM
  #32
MiniToBe's Avatar
MiniToBe
They are not prewired. You have to find the wiring and splice into the system. After that, you need to recode the CAS and JBE to recognize the system. Then you need to program new keyfobs that have the CA option. The unknown issue now is if the original CAS can support the CA option in terms of having correct software.
Old Mar 21, 2022 | 05:51 AM
  #33
UkJcw's Avatar
UkJcw
I have to change only the internal wiring or it of the engine too !!
Old Mar 21, 2022 | 05:54 AM
  #34
MiniToBe's Avatar
MiniToBe
Internal only. Before changing the wiring harness, check the wiring diagram. You might be able to splice in some wires and other wires are independent (go to the antennas).
Old Mar 21, 2022 | 07:22 AM
  #35
Yep its a big job and never seen anyone do it, they just talked about it.
Old Mar 21, 2022 | 08:16 AM
  #36
MiniToBe's Avatar
MiniToBe
i just looked at the wiring diagram. it is not that complicated really. you need 5 antennas, power, k-can tap, a wire to the rearview mirror, a wire to the wakeup signal, and door handles. the issue is programming the new keyfobs.
I do have a mini with CA and one without, I might try swapping the CAS and program a new key to see if it will fully function.
Old Mar 21, 2022 | 09:56 AM
  #37
UkJcw's Avatar
UkJcw
It would be great because I really miss my old r56 jcw because I loved the comfort access option
khumpert
Nov 30, 2015 11:48 AM
xpunisherx
Sep 1, 2015 11:47 AM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
mcoopers81
Aug 19, 2015 01:42 PM
