Coolant Leak near upper radiator fan hoses
Old Sep 24, 2009 | 02:28 PM
cooperdude's Avatar
cooperdude
I'm getting some coolant buildup on the hoses in the front of the engine just behind the radiator on the passenger side.
I cleaned off the short hose coming off the top of the radiator, drove the car 20 miles this morning, and i'm seeing the same stuff again. Its a slow leak, but its there. Could it be from the radiator itself since it only really appears after a drive, not sitting idle?
Its an 04 MC and is approaching 120,000 miles. Any ideas?
See pictures below:
Thanks.
Old Sep 24, 2009 | 04:03 PM
quikmni's Avatar
quikmni
I believe your radiator is plastic. Look very closely for a crack in the plastic.
Old Sep 24, 2009 | 05:02 PM
go_mini_go's Avatar
go_mini_go
You def got a leak. You really cant ID the problem without pulling off that hose for a closer inspection.
You could get lucky and find that the hose is failing.
Old Sep 25, 2009 | 01:32 PM
bungi's Avatar
bungi
I have an 05 MCS w/70k miles, but had the same exact problem. Took it into the stealership & they said there was a crack in the radiator, right where the hose is clamped on. They quoted me $800 to replace the radiator.
Cereall
Sep 5, 2019 06:05 PM
Khai
Feb 6, 2017 09:24 AM
KrisMiss
Jan 3, 2016 02:02 PM
alistaircookie
Oct 8, 2015 10:52 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
