weird knocking when idle
Old Jun 27, 2009 | 10:49 PM
friday9x's Avatar
friday9x
I have this knocking sound at idle when I start my car. It completely vanishes after one minute or I drive the car a short distance.. Any ideas? my oil level is fine..
2003mc 73k
Old Jun 28, 2009 | 08:19 AM
Yo'sDad's Avatar
Yo'sDad
Need more info:
Do you have an oil pressure gauge?
Is it a tap or a deep knock?
Have you raised the bonnet and listened more critically to determine what part of the engine or other areas the noise is coming from?
Try this. Raise bonnet. Pull each spark plug wire off and put them back on, but don't worry about the valve cover seal. This is just to loosen them up.
Have someone start the car. While wearing insulating gloves, or using rubber handle pliers, remove one spark plug wire at a time and listen for a change in the knock sound. Do all four wires one at a time.
When finished, turn off engine, and properly refit the wires to the spark plugs.
Then report back to us.
YD
Old Jun 28, 2009 | 08:30 AM
BlimeyCabrio's Avatar
BlimeyCabrio
The gloves part is important... I got arced a while back when just wiggling the wires while running.... Owwwww....
Old Jun 28, 2009 | 09:37 AM
friday9x's Avatar
friday9x
the sound is more of a tap. I dont have a oil pressure gauge but i will try the spark plug thing today. I dont have any insulating gloves but I do have some nice rubber pliers.
Old Jun 28, 2009 | 02:31 PM
BlimeyCabrio
Metallic tap or plastic-sounding tap?
I have an intermittent plastic tap I'm trying to track down.
Old Jul 3, 2009 | 02:04 PM
DaveVT02S's Avatar
DaveVT02S
I have a tapping noise, maybe similar: occasionally, while idling after cold start, my MINI sounds like someone's lightly rapping a knuckle on a heavy plastic box; goes away after a minute or so of driving (I've always let my vehicles idle for a minute or two before driving 'cold') - noise is regular, speeds up with engine speed - happens winter or summer - hard to track down source with the extra noise from CAI, etc...
Old Jul 23, 2009 | 06:31 AM
davegood's Avatar
davegood
I have this too
almost sounds like a gurgling sound when I start the car - lasts for about 2-3 miles - noticeable when idling, thought it might be the a/c condenser, but still occurs if I turn it off.
Old Jul 23, 2009 | 08:02 AM
Crashton's Avatar
Crashton
The gurgling sound is a symptom of low coolant. Mine did that when I had a leaking thermostat housing. You may want to check the coolant level..
Old Jul 23, 2009 | 08:44 AM
davegood's Avatar
davegood
thanks - I just looked and it is absolutely below the min level.
two questions:
what kind of coolant do I need - BMW / any kind / just water?
if it is low, does that mean the there is definitely a leak?
Thanks!
Old Jul 23, 2009 | 09:03 AM
Crashton's Avatar
Crashton
I did not use the BMW/MINI coolant. I added Prestone all makes all models 50/50 coolant.
Don't know if you have a leak, but your coolant is going somewhere. A leaking thermostat housing is a very common problem. What year is your MINI? If you are still under warranty go to the dealer.
Old Jul 23, 2009 | 09:07 AM
davegood's Avatar
davegood
I have a 2005 MCS - only 40k on it, but no longer under warranty. Do you think that I should just add some coolant and keep an eye on it?
Old Jul 23, 2009 | 09:53 AM
Crashton's Avatar
Crashton
Well for the time being I think that would work. It will give you an idea on home much & how fast you are losing coolant. The leak is not very likely to get better on it's own. You must keep an eye on it, over heating your MINI can end up costing much more that the leaks repair would cost.
JHolland
Sep 24, 2020 08:20 AM
rt808
Sep 29, 2015 03:15 PM
Miniwaukee
Sep 29, 2015 09:22 AM
whowantstorace
Sep 27, 2015 06:16 PM
rt808
Sep 25, 2015 01:59 PM
