Replacing backup / reverse light
Old Sep 3, 2012 | 03:09 PM
  #26
nUgZ's Avatar
nUgZ
Wanted to add a little info to the thread. I was having the same issue on my 2002 Cooper S. I changed the bulb...nothing. I found this thread so I went to my Mini dealership and had them order the switch. Replaced the switch yesterday afternoon...nothing. After some troubleshooting with my multimeter I discovered that all the connectors and switches were working fine. The problem ended up being the contact on the side of the connector where the bulb goes. It was pushed back and wasn't actually making contact with the bulb. Pulled it out some and it worked like a charm. Oh well...you live and you learn.
Old Sep 8, 2014 | 08:56 AM
  #27
Bcoday's Avatar
Bcoday
Updated: I was able to find the cable by removing several items above the reverse switch. In case it helps anyone in the future, the cable originates from under the fusebox in the engine compartment. Keep in mind that this refers to a 2009 r56. The connector was simply overlooked when my mechanic replaced the engine the last time. Reverse lights now work as they should.
Original post:
I've been searching for some pictures or info on a weird problem that I'm having with my back up switch on my r56 (yes I know what forum this is but it appears that someone in this thread might be able to help my particular problem!)
I found the back up switch and there is no cable attached. I've searched what I can see and I don't see the plug or wires. Does anyone know where the wires and cable connecter originates? It might help me know where to focus my search. Thanks if you can help!
Old Oct 28, 2021 | 11:01 AM
  #28
Riddick1775's Avatar
Riddick1775
Very nice write up and display of pictures/steps. I know this is a very old post, but hoping someone can help me. I have the new switch and found the hole for it (thanks to your pics), but the sensor is gone and I can’t find the wiring for it to connect the new one. I don’t know if it was loose and fell out or what, but it’s gone. I have looked all over for the wire/connector, but am clueless as to where it is. Any idea where the wire runs from to go to the switch in the transmission?
Thank you in advance!
Old May 22, 2024 | 08:27 AM
  #29
Ocoanater's Avatar
Ocoanater
Originally Posted by gknorr
For those who have done this - is the back-up light switch a male connector?
I'm hoping to solder in a connector to the old CVT wiring harness for the 6-speed swap I just had done. I know which wires to use, etc., I just need the connector that plugs into the backup light switch. I'm wondering if the #9 part, which is a female connector, is what I need:
#9 includes all of these, so it does seem like it's not part of the back-up switch:
PLUG CONNECTION FEMALE - 12527511315
Gasket - 12527511334
Socket housing - 12527511347
Locking mechanism - 12527511349
I can't get a good look at it unless I remove the battery box. Hoping I can get answer here before going that route to save a little time...
Please let me know if you finished this because I just put a 2006 Mini s. 6-speed LSD into my originally CVT 03. I'm unsure of what electrical connectors need to be fabricated or installed. Please let me know!
Old May 22, 2024 | 08:53 AM
  #30
gknorr's Avatar
gknorr
Yes, I was successful almost 12 years ago getting it wired in and working correctly. You'll need that plug. You can get all of the parts from the dealer or just cut a used one off at a local pull your own yard.
Number 9 parts in this diagram:
https://www.realoem.com/bmw/enUS/sho...diagId=23_0917
I also wired in cruise control for it some point many years ago, which involved adding a pin to the the engine computer wiring harness - it was pretty nerve-wracking.
Old May 22, 2024 | 09:04 AM
  #31
Ocoanater's Avatar
Ocoanater
You are an absolute legend for responding so fast to a random post from 12 years ago
pizzaman09
Jun 19, 2017 10:31 AM
brucetav
Dec 16, 2012 06:53 AM
PhilV89
Electrical
Feb 8, 2012 08:55 PM
41 Keys
Apr 18, 2010 12:13 PM
claancy
Jun 25, 2009 03:01 PM
