My temp shows in C, not F! Why? How?
Old Sep 27, 2008 | 02:53 PM
Goodwood's Avatar
Goodwood
The external temperature displayed on the tachometer as well as the temperature I set the AC/Heater to both show in Celsius! This happened out of the blue a month ago. It went away after a few days but now it's back!
This is my daughter's '03 CVT. We bought it used and don't have an owner's manual. I've searched but been unable to find any thread on this topic here.
Any help on how to set these displays back to Fahrenheit would be appreciated, and any advice on whether this phenomenon is a sign of a bigger problem to come also.
Old Sep 27, 2008 | 03:55 PM
volki
Press and hold the Auto button on the A/C controls until it changes back to F. That's the only way to do it actually. Someone must have been pushing the button little longer than necessary
Old Sep 27, 2008 | 03:58 PM
Goodwood's Avatar
Goodwood
Thanks!
I would never have figured that out in 10 million years.
Thanks much.
Old Sep 27, 2008 | 09:04 PM
ScottRiqui's Avatar
ScottRiqui
Did that work for you? Pressing/holding the "Auto" button doesn't do anything on my '06, as far as I can tell.
To switch between °F and °C on mine, I have to press/hold the A/C button (the "snowflake"), and then while I have it held down, tap the footwell vent button (the lower-right button on the A/C controls). To toggle it back, I release both buttons and repeat the procedure. This changes the display both at the auto A/C controls and in the tach.
I guess the procedure might have changed between '03 and '06.
Old Sep 28, 2008 | 11:35 AM
volki
As you mentioned, the procedure, as well as the button layout/labeling, are different between 03 and 06.
Old Sep 28, 2008 | 03:04 PM
Goodwood's Avatar
Goodwood
worked perfectly for me.... on my daughter's '03 CVT... I tried it on my '03 S and it works the same way.
thanks again.
Old Sep 28, 2008 | 03:12 PM
ScottRiqui's Avatar
ScottRiqui
Glad it worked out for you. I'm happy to have learned something new from this thread as well. I didn't realize that procedure was one of the things that changed with the "facelift" in 2005.
Old Sep 28, 2008 | 07:27 PM
Edge's Avatar
Edge
AdMINIstrator
Neither did I... they probably had too many complaints from people who switched it by mistake, so they made it more difficult to switch.
Old Sep 4, 2011 | 06:27 PM
mejerry's Avatar
mejerry
Worked for my daughters 04 MC. Press and hold Auto button. Couldn't figure out how it got that way but now we know the solution was also the cause: daughter held Auto button down too long. Thanks again.
patsum
26
May 29, 2021 06:29 PM
dinomaniac
Sep 18, 2018 04:19 AM
wyliec0y0te
Sep 15, 2015 01:13 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
