Water on Drivers Floor
Old Aug 3, 2008 | 11:39 AM
hudmg0kw's Avatar
hudmg0kw
I am getting water on the drivers floor area. It's enough that I can now have that horrible mildew smell. The problem does not seem to be connected to rain and my suspicion is a clogged AC drain tube. Does any have pictures of where the drain tubes are located? This is on a 2006 S.
The car is still under warranty but closest dealer is 100 miles away so, if it's a easy fix, I would prefer not to burn $4 gallon gas.
Also, any suggestions about getting rid of the mildew smell?
Any help would be appreciated.
Old Aug 3, 2008 | 11:54 AM
bobj's Avatar
bobj
Do you have a Sunroof?
Old Aug 3, 2008 | 12:06 PM
hudmg0kw's Avatar
hudmg0kw
No, I don't have a sunroof. Probably should have noted that in the original post.
Old Aug 4, 2008 | 08:11 AM
zmanrz's Avatar
zmanrz
its probably you ac drain. happened to my floor when the tech pinched off mine when installing my header. not sure where it is located, but its probably your culprate
Old Aug 4, 2008 | 12:39 PM
bobj's Avatar
bobj
+1 Especially if it is getting wet when it is not raining. Sometimes the drain gets plugged from below and just needs to be cleared with a piece of wire.
embiggenedmini
Oct 15, 2015 12:36 PM
wildwestrider
Sep 4, 2015 06:25 AM
F55MidnightBlackCooperS
Sep 3, 2015 04:02 PM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
