!!-How do you remove a Wiper Relay?
Old Jul 13, 2008 | 03:27 PM
gotundersteer?'s Avatar
gotundersteer?
Does it just pull out?
I gave it a good yank but had no dice. Does it just pull?
Old Jul 13, 2008 | 09:51 PM
xnotfunkylex's Avatar
xnotfunkylex
Are you talking about the wires that go into the rear wiper motor? If so there is a tab that needs to be pushed in to release the harness.
Old Jul 14, 2008 | 10:52 AM
gotundersteer?
No, I'm talking about the relay that is located on the fuse panel in the engine compartment. It's a black, squareish relay.
Old Jul 15, 2008 | 01:18 AM
Ancient Mariner's Avatar
Ancient Mariner
Relays basically plug in. No locking tabs or such. Sometimes a small, thin-bladed screwdriver slipped underneath to gently pry up will help.
Important!: Make sure you don't stick it in far enough to short out any of the prongs with each other. Once it's started, wiggling it side to side while pulling should get it out.
Old Jul 15, 2008 | 01:22 AM
friuli's Avatar
friuli
well, did you get it out?
Old Aug 7, 2019 | 01:47 PM
Jeff Kurzner's Avatar
Jeff Kurzner
Did you ever get the relay out and was that the problem? Dealing with stuck wiper in 2012 countryman
Accessory Products
Aug 25, 2015 10:03 AM
greekzilla
Aug 23, 2015 03:44 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
