2002 brakes
Old May 22, 2008 | 01:02 PM
GregO's Avatar
GregO
2002 brakes
Hey All,
Looking for good or bad results from changing the brake pads on first gen base cooper (2002). I know it's recommended to change the rotors and pads together, but any problems with changing just the pads?
Thanks! Greg
Old May 22, 2008 | 01:10 PM
Capt_bj's Avatar
Capt_bj
depends
really depends on your wear....how badly scored are the rotors... or if you want to be 100% correct, you would need to have the old rotors resurfaced and check the minimum thickness stamped on the rotor
but many, like me, have gone thru two sets of pads before changing the rotors.
On the other hand, if you will DIY this job, the additional work to swap the rotors too is minimal and you can pickup basic rotors (Brembo for example) fairly inexpensively; especially as compared to the cost of having them recut which will cover almost half the cost of new in many cases.
Old May 22, 2008 | 01:11 PM
daemon2's Avatar
daemon2
It depends on the condition of the rotor. If the rotor is grooved you can have it turned at a local auto shop if worn below spec it should be replaced.
If the rotor is in good shape, just replace pads. Both the rotor and pad expericence wear.
gmonde
Sep 28, 2015 05:22 PM
Gremothra
Sep 9, 2015 08:42 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
