cooling fan question
Old May 12, 2008 | 06:03 PM
diptenkrom's Avatar
diptenkrom
i am having an overheating problem. the car is fine while driving, but overheats if you sit still. antifreeze boiled out once.
50 amp fuse for fan blows if fan is plugged in. does not if not plugged in. the fan does not run from what i can tell.
ran hot wires straight to the connectors for the fan plug, and a groiund to a bolt on the bumper mount... they heated up, but no fan response.
is this teh fan itself or the resistor that i keep reading about? also is there a way to bypass the resistor and test the fan itself? can i fix this with some kind of wiring setup, or is replacing the whole assy the only way out?
also i thought about an aftermarket fan, and the prob i found is that i think the oem fan is 2speed. is this the case? can i run an aftermarket without the resistor?
Old May 13, 2008 | 04:02 AM
diptenkrom's Avatar
diptenkrom
3 wires go into the resistor and 2 into the fan. so i am assuming the resistor is some kind of relay. one wire is ground one is always hot, and the other i assume is the trigger cause from reading others posts it is not always hot, but if 12v is supplied to it then the other guys fan would work. mine still did not.
also how is the second speed triggered? i see 2 relays under the fuse panel, but how is that set up?
Old May 13, 2008 | 07:36 PM
diptenkrom's Avatar
diptenkrom
so nobody else knows either?
well here is what i found out. the fan is actually stuck. i can not turn the blades by hand. so the only way i can figure to fix it, without spending $300 would be to pull the fan and wire another one in. pretty sure that the resistor is not a problem.
three wires into the resistor and 2 out the fan. ground and hot to the resistor as well as a trigger wire. and +/- to the fan itself.
Old May 15, 2008 | 12:44 PM
diptenkrom's Avatar
diptenkrom
well no info so far... one more
is the fan speed controlled by voltage, or amperage?
Old May 15, 2008 | 02:35 PM
Xymox's Avatar
Xymox
http://www.mini2.com/forum/
Give them a shot. Maybe they can help ya out.
Longjas
Factory JCW Talk (2009+)
Nov 2, 2015 02:28 PM
alistaircookie
Oct 8, 2015 10:52 AM
robbiedowns22
Aug 25, 2015 12:20 PM
Chippawaguy
Aug 19, 2015 10:59 AM
ki7hy
Aug 12, 2015 07:07 PM
