Evap system leak
Old Apr 14, 2008 | 06:43 PM
MRmidge's Avatar
MRmidge
Evap system leak
Just after i pulled the super charger I started to get an evap leak. It started at first with the gas cap light, went to a small evap leak code. Then it got to a large leak code. I'm curious if it's something i did , or if it is just coincidence. Anyone familiar with the evap system, or should i just fold and take the car into the dealership.
Thanks for any help,
Brian
Old Apr 14, 2008 | 11:15 PM
Ancient Mariner's Avatar
Ancient Mariner
Start with the Purge Valve located on the engine. On the MC, it's located on the left side almost directly above the tensioner pulley. Two black hard plastic 3/8" tubes -one coming in the bottom, one going out the top. Maybe you cracked on or knocked it loose. Or the wiring harness going into it got knock loose. (but that's a different code, I think)
-skip-
Old Apr 15, 2008 | 01:14 PM
MRmidge's Avatar
MRmidge
thanks I'll give that a double check. I'd really hate to take it into the dealership for something i did.
Etrain
16
Aug 5, 2024 04:37 AM
woodstudio
Mar 15, 2020 08:28 AM
Khai
Feb 6, 2017 09:24 AM
pocketmaster
Aug 6, 2015 01:41 PM
