Check Engine Light and Tire Pressure monitoring
Old Apr 5, 2008 | 10:27 AM
Jon@TheMshop's Avatar
Jon@TheMshop
Hey guys!
Need some assistance here. I already did a search but still need more help.
Vehicle is a 11/02 production date Cooper S. Customer has a CEL and TPM light. We had a bunch of CAN bus faults in the DSC control unit along with a steering angle sensor fault.
We installed, recode, calibrate two steering angle sensors with different part numbers but some faults keep on returning. I have no fault codes for MAP or wheel speed sensors.
Fault codes are:
5E1E - steering angle sensor CAN
5E16 - CAN Connection to instrument cluster
5E1F - Vehicle identification number different.
Any thoughts? I am starting to suspect a faulty DSC control unit or wiring.
TIA.
Old Apr 5, 2008 | 06:00 PM
Central Coast Coopers's Avatar
I have heard of it
and the local dealer, under warranty, replaces the stg angle sensor and all 4 wheel sensors att he same time-unclear on what this did except the parts were all from a current production batch. the dealer would not confirm or deny a software discrepancy between different generations of sensors, but that is what cured it.
Old Sep 30, 2008 | 01:44 PM
Jon@TheMshop
OK an update on this issue: We had to disconnect the DME while programming/coding the new steering angle sensor. It was causing some sort of interruption. reconnect the DME after coding the sensor and everything is fine.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
Lt. Dan
Aug 10, 2015 08:23 AM
nomar116
Aug 9, 2015 09:42 AM
