vibration when accelerating
Old Mar 17, 2008 | 01:40 PM
MUShadd's Avatar
MUShadd
I had my pads/rotors changed this past weekend. on the drive home on the interstate, I noticed a vibration of the entire car when accelerating. If i let of the gas and coast, or maintain a constant speed, the vibration goes away. I got home and removed the wheels, check the lugs and torque. the problem still persists. I can only feel the vibration at higher speeds 60+. Seems like if it was an balance issue, that it would do it consistently, not just when accelerating. normal city driving is perfectly fine, brakes and all work great....any ideas?
Old Mar 17, 2008 | 06:45 PM
MRmidge's Avatar
MRmidge
Vibration only upon acceleration is usually a sign of a u-joint or drive shaft issue. Thats the only help i can be, i hate to say. Hopefully it is an easy fix, and nothing to expensive.
Old Mar 17, 2008 | 07:36 PM
Ancient Mariner's Avatar
Ancient Mariner
Check and see if the shop knocked a wheel balancing weight off while they were doing the brakes.
-skip-
Old Mar 17, 2008 | 08:29 PM
MUShadd's Avatar
MUShadd
i'll check the weights, and i guess have the dealer check it out while I have it this weekend with other warranty work.
Old Mar 18, 2008 | 08:01 AM
D3m0N's Avatar
D3m0N
also make sure calipers are releasing fully from the brakes
minieater
Oct 28, 2015 02:15 PM
randeez
Oct 5, 2015 09:23 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
thadscottmoore
Sep 25, 2015 10:07 AM
gpwpat
Sep 15, 2015 11:58 AM
