Too lean code
Old Mar 12, 2008 | 07:41 AM
grillhands's Avatar
grillhands
Too lean code
Does this mean it's time for injectors? I've never had this problem before and all of a sudden it's happening almost everytime i drive. I didn't add any new mods to the car yet. Anyone have this happen to them?
Old Mar 12, 2008 | 07:53 AM
Modshack's Avatar
Modshack
No! You should find the problem, not cover it up. Could be a VAC leak or 02 sensor..
Old Mar 12, 2008 | 08:37 AM
grillhands's Avatar
grillhands
I just put a brand new 02 sensor in last week so i don't think its that. I'll check all my connections again. Is there any common spots where it might be leaking from?
Old Mar 12, 2008 | 08:49 AM
Modshack's Avatar
Modshack
Well...If this has occured since the 02 install, I'd look carefully at what you did...Sensor could be faulty, though that's rare...
Old Mar 12, 2008 | 10:00 AM
grillhands's Avatar
grillhands
I had a check engine light ever since i got my header installed. When i used my scanner it said 02 sensor bank 1. I looked under the car to see that when the guy installed my header he plugged in the 02 connection than started to screw in the sensor. The wires were wound up so tight that the black wire broke off. I replaced that sensor and everything was fine for about 5 days. Then one day as i was driving it came on.
Old Mar 12, 2008 | 01:23 PM
grillhands's Avatar
grillhands
Just put in my Volt exhaust that is much quiter than my straight pipe. To my surprise, i heard a hissing noise coming from my Methanol Tank. One of the vacuum lines wasn't sealed all the way! I am about to do another test drive to see if i still hear the hissing noise but i think that's it.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
Enjoytheride
Sep 17, 2015 12:10 PM
HaveATank
Sep 16, 2015 08:32 AM
smbmkay
Sep 11, 2015 09:45 AM
