My bonnet wont open ??
Old Feb 23, 2008 | 01:52 PM
minimonsterthunder's Avatar
minimonsterthunder
So today I installed the M7 STB. This was a hassle in itself. I had quite a bit of mushrooming and had to hammer my strut towers quite a bit. When I finally installed the STB I closed the hood to see if it would close properly since the STB is known to lift the hood. It turns out the hood is slightly raised so I pulled the the latch to open the hood and only one side unlatched. The driver's side didnt budge. After fiddling around with it for some time I still cant open my bonnet. ANy ideas???? I think the drivers side latched properly but then wont unlatch. Is there an alternative way to open the hood to fix this? ANy help is appreciated.....
Old Feb 23, 2008 | 01:57 PM
minimonsterthunder
by the way...the cable for the drivers side is pure slack...so im thinking I accidentally detached the end to the mechanism during my hammering. How do I unlatch the bonnet manually?
Old Feb 23, 2008 | 04:49 PM
fullcollapse40's Avatar
fullcollapse40
take off the drivers front wheel, remove the plastic fender liner, then you will have access to the latch mechanism
Old Feb 23, 2008 | 04:57 PM
Modshack's Avatar
Modshack
Or (assuming the cable is still attached), have someone apply downward pressure on that side while you pull the release..
Alpha Motoring
Sep 7, 2020 07:34 PM
minimacattack
Metroplex MINI - Texas
Oct 18, 2016 01:24 PM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
simo711
Oct 1, 2015 05:36 AM
minimacattack
Sep 25, 2015 07:37 PM
