Minimum Rotor Thickness?
Old Feb 17, 2008 | 02:29 PM
emcguy's Avatar
emcguy
Can anyone tell me what the min thicknesses are for the front and rear rotors? My dealer replaced the frons (20.3mm) but not the rears (9.1mm).
I'm at 34K and I figure I'll end up getting stuck doing the rears on my own.
Thanks!
Old Feb 17, 2008 | 11:59 PM
verveAbsolut's Avatar
verveAbsolut
Thanks!
Should be printed on the edge of the rotors, but...
Bentley sez:
Front
New: 22mm
Wear Limit: 19mm
Rear:
New: 10mm
Wear Limit: 7mm
Oh, and when you do get around to doing the rotors, realize that the caliper carrier bolts (not the allens) and the Torx bolts are probably torqued north of 120lb/ft from the factory/last ******* who did the job...I had to use a breaker bar and gobs of penetrating oil to get them loose and off. Take your time and don't strip them. I can show you a nice picture of a shattered, from the inside-out, non-impact socket I created when doing this job.
Carrier bolts should be 81 lb/ft (front), 48 lb/ft (rear), rotor torx bolt should be 20 lb/ft.
- Matt
Old May 31, 2009 | 02:59 PM
ztx's Avatar
ztx
TIS info
From TIS:
Front minimum thickness 20.4mm
Read minimum thickness 8.4mm
Old May 31, 2009 | 03:17 PM
JAB 67's Avatar
JAB 67
After about 65K my fronts were down to about 16.5 mm.
Old May 31, 2009 | 03:44 PM
minilites's Avatar
minilites
Unless your absolutly on a budget why bother getting them turned
you can find new rotors at a good price at a place like AutoZone.just a
thought.
FatherG
Oct 3, 2015 05:06 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
