Poll: how often do you have to reset window dip function?
Old Jul 21, 2003 | 03:55 PM
MG-BGT's Avatar
MG-BGT
Ok, I am beginning to get really annoyed at the frequency with which I have to reset the window dipping function: on average, twice a week now. This is even after I have had the drivers side motor and controller replaced because the window stopped working.
How often do you have to reset the window dip function?
M.
Old Jul 21, 2003 | 03:58 PM
mully1217's Avatar
mully1217
I've never had to...and I've had mine since August 23, 2002!
Erin
Old Jul 21, 2003 | 04:02 PM
Driving_Hamster's Avatar
Driving_Hamster
Didn't even know that you could do this on your own?! How does one accomplish this should it be needed?
Old Jul 21, 2003 | 04:05 PM
zagato67's Avatar
zagato67
Not terribly often- usually every third time after I've run through a car wash (OK, stop being horrified- I go to a local "touchless"!) and I open my door and the window doesn't jog down. I am worried about it though- I'm curious to see how British long-term build quality meshes with German design detail. A friend with an X5 has demonstrated that South Carolina build quality doesn't mesh with German design detail on that one...
Donald
Old Jul 21, 2003 | 04:10 PM
Cynamini's Avatar
Cynamini
This has only happened to me once. Somehow when the door was open and I put up the window it didn't go up all the way. So the next day I could here air coming in from somewhere...so all I did was open the door and roll up the window again. All fixed. I don't know why this happened...maybe someone else will know???
I hope this helps a bit.
Old Jul 21, 2003 | 04:16 PM
MG-BGT's Avatar
MG-BGT
When you open the door the window goes down like 1/4". Close it, it goes back up again. Mine often stops doing that, and I notice it when II try to close the door and it won't, or only when slammed real hard and then the window overlaps the trim.
The bad thing is if your passenger slams the door and gets it closed ok when the dip stops to function, so you don't notice the overlap. Then you walk away, and it starts raining. You can imagine the rest
To reset, open window all the way, close door, roll window up and hold the up button for another 7-10 seconds after it has reached the top. This will reset the dip function.
I just wanted to know how often this happens to others to get an idea whether it's worth complaining to the dealer about this. I guess it is.
The electrical system in this car is REALLY beginning to annoy me.
Sorry for the rant!
M.
Old Jul 21, 2003 | 04:20 PM
Moorlockx's Avatar
Moorlockx
Driving since mid-March with no problems on the windows.
Old Jul 21, 2003 | 04:29 PM
Nuvolari's Avatar
Nuvolari
>>Sorry for the rant!
>>M.
Have never had that problem. I have the problem where the boot latch gets out of sequence and won't close.
Everybody gets something from a small list of problems. This is apparently a feature of British cars. They would say it helps build character.
Old Jul 21, 2003 | 04:40 PM
Nomonstersinme's Avatar
Nomonstersinme
i've never had that problem, but ive often wondered if people had that problem..
Old Jul 21, 2003 | 04:59 PM
gokartride's Avatar
gokartride
Never happened to me.
Old Jul 21, 2003 | 05:02 PM
tsprayfhs's Avatar
tsprayfhs
after 18,000 miles I can say ... never. I would have a long terse conversation with the dealer. The only problem I have had is the leaking overflow. The car has been great. Sorry about yours.
Old Jul 21, 2003 | 05:16 PM
SCoop's Avatar
SCoop
No problems here.
Old Jul 21, 2003 | 06:30 PM
GaryA's Avatar
GaryA
I've had mine since June 2002 and have never had a problem.
Old Jul 21, 2003 | 07:06 PM
Chitown_COOP's Avatar
Chitown_COOP
Coordinator :: Chicago MINI Motoring Club
Been driving MINI(s) for 16 months now. Never happened. Maybe you're special!
Old Jul 21, 2003 | 07:27 PM
Kohu'ulaMINI's Avatar
Kohu'ulaMINI
Since new 4 mos. ago, had to reset it twice.
Old Jul 21, 2003 | 07:36 PM
Nobull60's Avatar
Nobull60
Um...Let me think ????? NEVER !!!!!
Yours needs a service Tech to fix it I would think.
Old Jul 21, 2003 | 07:37 PM
Phobol's Avatar
Phobol
Never... hmm, yep never.
Old Jul 21, 2003 | 10:37 PM
bgrpph's Avatar
bgrpph
I have having to reset mine constantly 03 MCS 11/02 build. it would work few days or week then stop dipping. seemed if you put windows up with door closed he dipping stopped working. if door was open when windows put up it would dip and work ok. Took it to dealer, they replace many of controllers, etc and tried 3 separate fixes, finally replaced controllers. worked for few weeks now its back to same old thing as before not dipping all the time. its back once again in few weeks.
Old Jul 22, 2003 | 12:24 PM
allen_shelton's Avatar
allen_shelton
Reset mine maybe three times in about 7 weeks of ownership. I don't recall ever having to reset the driver's door...only the passenger side (which very rarely gets used). Maybe a sticky switch or something? I would assume the same switch is tied into both the dome light and the window dipper but I've never noticed if the dome light fails to work when the window doesn't dip.
Old Jul 22, 2003 | 12:34 PM
orbhot's Avatar
orbhot
never (knock on wood?)
Old Jul 22, 2003 | 01:02 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Havent had to yet on my '03 MCS. I did have to tear apart the back of the boot to fix the latch the other day, it had gotten stuck open. So far so good there.
Old Jul 22, 2003 | 01:15 PM
greatgro's Avatar
greatgro
Happened once since I got the car last October. 21k miles now.
Old Jul 22, 2003 | 01:16 PM
red03miniS's Avatar
red03miniS
i never have to, mine is perfect
Old Jul 22, 2003 | 02:45 PM
MG-BGT's Avatar
MG-BGT
Mine is Dec 6 02 build MCS. Maybe they had some bad parts back then. Happened again today, and it's really ticking me off now!
Old Jul 23, 2003 | 06:41 AM
MGCMAN's Avatar
MGCMAN
Ditto.
