Reverse
Reverse
I have read it before but when I try to shift into reverse (MC 06, right hand drive) its a bit tough, if I do it with one hand it has the chance of clanking when I put it in reverse. With two hands and a bit of gentle slow force it works fine. I have been told to change the transmission fluid. Any tips?
You might try letting out the clutch a little as you shift into reverse. Keeping your other foot on the brake of course. Should pop right in.
The S-lites on your MC look great!
I'm in the habit of going into first gear and then right into reverse, clutch depressed the whole time, and I don't get the gear clash. A little trick from my non-synchroed Early Bronco days w/ a granny gear transmission. It seems to work.
Later
Later
vulkandino
Oct 31, 2015 08:29 PM
MINI Stupor
Oct 1, 2015 11:36 AM
