I think my hood scoop is melting...
Old Feb 19, 2008 | 10:27 PM
  #51
daffodildeb's Avatar
daffodildeb
My week 3 baby was in for her oil change (first OFFICIAL), and I asked about the open scoops. She said she'd check about it to see if I could get a new scoop.
Yeah, right. And the Tooth Fairy knows Santa.
Old Feb 20, 2008 | 06:23 AM
  #52
r56mini's Avatar
r56mini
Originally Posted by evilarry
corona is a pretty lame name man, come on
my favorite drink..
Old Feb 20, 2008 | 07:46 AM
  #53
Rubbus's Avatar
Rubbus
Nuthin' wrong with "Corona" as a name. Don't mind the haters!
Old Feb 20, 2008 | 10:26 AM
  #54
daffodildeb
Hey--never criticize a guy's mama, or the name he gives his car!
Old Feb 20, 2008 | 11:18 AM
  #55
russr's Avatar
russr
daffodileb, how much of an issue is the heat on your hood scoop?
Old Feb 20, 2008 | 11:54 AM
  #56
daffodildeb
It gets VERY hot on and around the scoop, as others have reported. Too hot to keep your finger on it, like a stove. I'd believe the 225-250 degrees others with a thermometer have reported. There is an ever-so-slight, but still noticeable depression in the center of the scoop "rim."
Old Feb 20, 2008 | 12:13 PM
  #57
russr's Avatar
russr
Is there no way to just replace the scoop with the part number that the late '07s and '08 models use?
Old Feb 20, 2008 | 12:25 PM
  #58
daffodildeb
Oh, I know it can be done, but I don't feel like paying for it. I think MINI should.
Old Feb 20, 2008 | 12:49 PM
  #59
russr's Avatar
russr
I wonder if that would resolve the issue for you though. What does the dealer say?
Old Feb 20, 2008 | 01:01 PM
  #60
daffodildeb
SA says "she'll check." See post #51.
Old Feb 28, 2008 | 05:34 PM
  #61
azminiman's Avatar
azminiman
Ours was the same way... Like I said in the earlier post.. Just remove the black honeycomb peice from the scoop.. We did, no more issue. 5 minute fix
Old Feb 28, 2008 | 08:55 PM
  #62
daffodildeb
I showed Hubby your comments (and the previous post), and his concern was that opening up the scoop might affect the air flow as it is designed. Which, of course, brings up the possibility that the warranty would be denied if anything showed up relating to the engine or turbo. Comments?
Old Feb 29, 2008 | 04:50 AM
  #63
korby's Avatar
korby
After seeing my friends newer semi open scoop I drilled a few open .
Old Feb 29, 2008 | 04:52 AM
  #64
Arnbut's Avatar
Arnbut
Now you've done it...
Old Mar 2, 2008 | 09:08 AM
  #65
azminiman's Avatar
azminiman
Quess depending on who services you car,, they could find a reason to blame it on a open scoop. (god only knows our dealers service is know for stuff like that) But, weather there is 1 hole, 5 holes, 10 holes, or totaly open, air and what ever is getting in. Oh well, good luck on finding a resolution, I found mine
Old Mar 2, 2008 | 12:05 PM
  #66
r56mini's Avatar
r56mini
I think mine has every other column open. In hot summer days, it still gets really hot. Carbon fiber scoops should have higher melting point.
Old Mar 2, 2008 | 08:46 PM
  #67
daffodildeb
Yes, a friend's newly delivered '08 has this, and I found it just as hot as minie (seemed so, anyway, without a temp gauge). There has to be a better solution.
Old Mar 2, 2008 | 08:49 PM
  #68
ChrisW's Avatar
ChrisW
Originally Posted by Hogtied
.. no joke.
A buddy recently asked how my hood scoop got 'dented'... I walked over to check it out, and by golly it does have a slight depression in the right/rear portion of the scoop. Not a big 'dent', but once you notice it, it's definitely there.
I knew it couldn't be 'dented' - since it's plastic, so I popped open the hood, and bingo!.. the indentation is directly over the turbo - just to the right of where the heat shield stops. (I'll shoot some photos so you'll know where I'm describing).
I had the car at the Mini dealer in Winston-Salem last week for some routine service, so I showed the service writer. He agreed.. so they're going to warranty my hood scoop (which will need painting once it arrives).
Anybody else notice the same thing happening to your scoop? I've been told that there's a mod to the scoop to eliminate this from happening, but I'm not sure what the mod is. I may take my Dremel and open some of the holes in the black plastic scoop filler to help vent the hot air.
WOW and its not even functional.
Old Mar 13, 2008 | 07:25 PM
  #69
azminiman's Avatar
azminiman
Yes it is.. It is fully functional thermal dissapation port
Old Mar 13, 2008 | 08:00 PM
  #70
daffodildeb
Why do people keep saying this? It IS functional when open, as the later builds are. Only the earliest cars have closed scoops. I have a week 3 build and I want to change scoops due to heat.
Old Mar 15, 2008 | 07:22 AM
  #71
miniemee's Avatar
miniemee
Mine is an early build and had same issue. Before, the annual servicing, I asked them about replacing it. They claimed to be "unaware" of the issue and suggested might be bad manufacturing of the part. However, they did replace the hood scoop after I emailed them a few pictures of it. Unfortunately, carbon black was 300.00 and is too pricey for me. I was told that they would keep replacing it anytime it happened.
Old Mar 15, 2008 | 08:30 AM
  #72
daffodildeb
Gee, your SA went to the same SA school that mine went to. Wonder how much time MINI saves by saying that they "didn't know" about a problem. Ours says it when I come in, and then again when someone else shows up with the same complaint--same model, same everything.
Old Mar 15, 2008 | 08:31 AM
  #73
daffodildeb
One other thing--what's the cost of a regular hood scoop, and does it require painting?
Old Mar 17, 2008 | 09:29 AM
  #74
korby's Avatar
korby
I took mine in for service today . The service guy could see it from 20 feet away ...perfect lighting for it . I bet they dont do anything .
Old Mar 17, 2008 | 12:27 PM
  #75
Arnbut's Avatar
Arnbut
Can't speak for BMW/MINI but, when I worked for a Honda dealer the management used to actually coach us in effective methods of prevarication. We all were required to follow the same trail of not-so-true.
Yes; I quit.
