A different seat heater problem
Old Jan 18, 2008 | 02:49 PM
Ladidah's Avatar
Ladidah
For the last few weeks the heated seat on my 2005 MCS seems to be extremely warm - warm enough that I cannot leave it on more than a few minutes. Is this a common (or even uncommon) problem? I don't know if my a$$ is just being sensitive or if there is really a problem, but if I leave it on it feels like my butt is on fire. We're heading into a weekend of sub zero temps and I need my heated seats!
Old Jan 18, 2008 | 03:01 PM
Deviant's Avatar
Deviant
I've heard of this in other MINIs (although mine seem to be fine) and believe there's a TSB out about it. Give your dealership a call and see if they can perform the fix.
Old Jan 18, 2008 | 03:11 PM
mcs22004's Avatar
mcs22004
You could just turn it down or turn if off when it gets too hot.
Old Jan 18, 2008 | 03:33 PM
Ladidah's Avatar
Ladidah
Thanks Deviant. I'll check it out.
mcs22004, that is what I do now. But it hasn't been this way in the past (I've driven it 2 winters already) and I didn't have this problem before (but maybe I'm more sensitive? - it is a judgment call). So that leads me to believe there is a problem with my seats, but I wanted to see if it were a common/slightly common problem. My warranty runs out in about 5k, so I'd better do it soon.
Old Jan 18, 2008 | 03:40 PM
cristo's Avatar
cristo
Alliance Member
Maybe the spacing between the temperature sensing element and the
heating element has shifted to cause the change.
There is a TSB and a fix with two different $20 in line adapters you can plug in to
make the seat run cooler or hotter than stock.
I got and inserted the one to cool it down a bit, and it does help.
Here's a thread about it.
https://www.northamericanmotoring.co...ad.php?t=94611
W0TM8
Dec 19, 2019 07:50 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Mini'mon
Aug 26, 2015 01:02 PM
Zettinger
Aug 25, 2015 04:04 PM
bseiden
Aug 15, 2015 10:16 AM
