Belt Tensioner Tool
Old Jan 15, 2008 | 07:25 PM
Montana Miniac's Avatar
Montana Miniac
Belt Tensioner Tool
Demolished my serpentine belt today. The pulleys on my Stock '02 S survived as did the tensioner I think. I now need a belt. Any one know the stock S belt size and can it be found locally through a parts house? Do I need to get a belt tensioner tool to install the belt? Will the Ultrik belt tensioner tool that Mini Mania sells fit a stock pulley assembly?
Old Jan 15, 2008 | 07:32 PM
MRmidge's Avatar
MRmidge
You can do it with out one, but by the 3rd hour or so, you'll try and find the tool. Outmotoring sells them, and it makes work on the car so much easier. Worth every penny i spent on it.
Old Jan 16, 2008 | 05:01 PM
Montana Miniac
I took your advice and ordered a belt and took today. Thanks (JD)
Old Jan 19, 2008 | 10:22 AM
Montana Miniac
One more beginner question. Is a stock belt the same as a "standard 15%" belt?"
Old Jan 19, 2008 | 09:40 PM
MINICHEF's Avatar
MINICHEF
go see a NAPA parts store. They can hook you up.
Old Jan 19, 2008 | 11:58 PM
yellowbritishrocket's Avatar
yellowbritishrocket
i just put a 15% pulley on and the napa belt i was given was 4060535
Old Jan 20, 2008 | 07:25 PM
MRmidge's Avatar
MRmidge
if you want a Gates belt that is for 15% the number is K060539.
Old Jan 21, 2008 | 07:17 AM
Montana Miniac
Thanks all for the help. Got the belt & tool. Belt is on. The actual belt installation took 5 minutes with the use of a tensioner tool and a friend holding it. Removing and replacing the wheel, inner fender and small stuff to gain access, took about a hour. This is a doable maintenance for the average guy who likes to change his oil and plugs. Having the tool helps a lot. First and foremost is to remember to change the belt before it breaks, like it did on me.
Old Apr 15, 2008 | 10:14 PM
actualsize's Avatar
actualsize
tool rental?
would you be willing to lend the belt tensioner tool? i'll be doing a pulley install on my own and the tool would help. Of course i'll be paying the shipping costs.
Old Apr 16, 2008 | 04:57 AM
Montana Miniac
You would be better off buying one from a site sponsor like OutMotoring.com. Then you will have one the next time you need one. Either save the old belt or order a extra new one for a spare.
Old Apr 16, 2008 | 11:21 AM
jrprich's Avatar
jrprich
I see a Cooper S tool listed but nothing for a standard Cooper.
Do both use the same tool? Wouldn't think so
Old Apr 16, 2008 | 01:21 PM
Montana Miniac
Good question! As I read my '02-'04 Mini Cooper Bentley Service manual. I see that special tool 11 8 390 is used to release the belt tension on the (Cooper) and special tool 11 8 410 is used for the (Cooper S). These are factory tool numbers. Though the engine layout is similar, the belt systems are different. You had better ask the vendor before you buy.
Old Apr 16, 2008 | 01:51 PM
Eric_Rowland's Avatar
Eric_Rowland
Nope.
Old Apr 16, 2008 | 03:07 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Originally Posted by Eric_Rowland
Nope.
In the Cooper non S there is a hole in the chassis with rubber plugs that you can stick a 3/4' extention though and turn back the tensioner. You may need to loosen the motor mounts to get it to line up.
Old Apr 16, 2008 | 04:20 PM
jrprich's Avatar
jrprich
I have searched Google and looked on many MINI sites........don't see a tool for the standard Cooper.
Anyone know where they are sold ?
Old Apr 16, 2008 | 05:16 PM
ScottinBend's Avatar
ScottinBend
You will need to check with Rasmussen for the Cooper tool. I don't know anyone that has an aftermarket one available.
Old Apr 16, 2008 | 09:33 PM
Ancient Mariner's Avatar
Ancient Mariner
Also, if you check in the boot in the little tool kit, there should be a short, heavy wire object with a looped end. It's supposed to be for removing the cover plates in the bumpers where the tow hook goes. It fits nicely into the tensioner hole to hold the tensioner in place while you change the belt.
-skip-
Old Apr 17, 2008 | 04:42 AM
jrprich's Avatar
jrprich
I shudder to think what a dealer would charge for a MINI tool
Old Apr 17, 2008 | 04:43 AM
jrprich's Avatar
jrprich
-skip-
Interesting
I will take a look, first time anyone has mentioned this
Old Apr 17, 2008 | 08:51 AM
jaridp's Avatar
jaridp
-skip-
That is the tool for popping off the hubcap.
Old Apr 17, 2008 | 09:07 PM
Ancient Mariner
-s-
Old Apr 19, 2008 | 10:56 AM
jrprich's Avatar
jrprich
More info please......got a pic of this location ?
What needs to be removed to get to the plug
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
hong
Sep 13, 2015 06:41 PM
Emnotek
Sep 11, 2015 04:16 PM
Sep 8, 2015 11:37 AM
