Heated mirrors??!!??
Old Dec 10, 2007 | 07:40 AM
JohnnyG's Avatar
JohnnyG
OK, now I've got another little issue....seems as if my heated mirrors have stopped working...
Are they ON when the car is on OR when the outside temp reaches a certain point? I've checked all the fuses I can (atleast the ones I think are related to the mirrors...I don't have a Bently yet)...and they all check out OK...
I haven't found a "manual switch" to turn them on/off....I'm going to pop the mirror faces off to make sure the wires are still attached to the little posts...
Anyone have any insight on this??
THANKS!!!!!!
Old Dec 10, 2007 | 09:17 AM
juaclark's Avatar
juaclark
They work in conjunction with the rear window defrost. The same button on climate control panel operates both simultaneously.
Old Dec 10, 2007 | 09:25 AM
cristo's Avatar
cristo
Alliance Member
No, they're on when the car is on (even in the summer).
Old Dec 10, 2007 | 09:30 AM
adam76's Avatar
adam76
Yep, constant heat running to the mirrors.
Old Dec 10, 2007 | 09:32 AM
humcmcel's Avatar
humcmcel
That explains why I've seen them clear aon a cool spring morning without turning anything on.
Old Dec 10, 2007 | 06:22 PM
lotsie's Avatar
lotsie
Always on, regardless of outside temp., thats why you get water spots on them after a rain.
Mark
Old Dec 10, 2007 | 06:35 PM
Eric_Rowland's Avatar
Eric_Rowland
You forgot to add the .
I swore that one of the first things I would do would be to add a switch to turn those off in summer (not that I need them in WINTER here. ) Sadly, that has not happened.
JohnnyG, I checked out the fuse box, and don't see any obvious fuse, though one would assume that they ARE fused somewhere.:impatient
Old Dec 10, 2007 | 06:39 PM
ToBFree's Avatar
ToBFree
If you can figure out the British version of icons. You'll be able to determine the fuse looking at the box cover. Try the fuses in the driver's side panel near the door under the dash.
Old Dec 10, 2007 | 06:42 PM
lotsie's Avatar
lotsie
Yeah Eric, I know baffles me too, they should come on with outdoor cold warning I wonder if they are tied in with the heated washer jets, which are also always on
Mark
Old Dec 10, 2007 | 07:15 PM
rkw's Avatar
rkw
The mirror heaters are on fuse F35. The mirror motors are on the same circuit, so whether or not you can operate the electric mirrors will tell you the condition of the fuse.
Old Dec 11, 2007 | 03:20 AM
juaclark's Avatar
juaclark
Oh, didn't realize that. I guess I've never waited long enough to notice, but they never seemed to clear until I hit the rear defrost button.
Old Dec 11, 2007 | 05:40 AM
LeeL's Avatar
LeeL
Next time it is warm outside, reach out and touch one of the mirrors.
Old Dec 13, 2007 | 12:29 PM
JohnnyG's Avatar
JohnnyG
well if the heat works when I can adjust the mirror, i've got a different problem cuz i can adjust them....maybe one or more wires have come off the back of the mirror.....weather is coming here this weekend and I'd love to get this fixed....guess it's time to pop the mirror off.....THANKS for all you help guys/gals
Old Dec 14, 2007 | 05:24 AM
JohnnyG's Avatar
JohnnyG
OK...I popped the mirror off last night....guess what....NO WIRES and NO PRONGS on the backs of the mirrors?????? Am I wrong...how can I have heated seats and washer jets but NOT the mirrors? I did buy the car used, and not from a Mini dealer but I thought all 3 of those items came as a "package"?? Is there a way for me to determine if the original buyer requested the whole package or bits and peices or is that possible?
I want my heated mirrors :(
Old Dec 14, 2007 | 12:24 PM
rkw's Avatar
rkw
That does seem strange. The Cold Weather package has all 3 items. But even as a separate option, heated mirrors are combined with heated washer jets. Are you absolutely sure you have heated washer jets?
Old Dec 17, 2007 | 06:48 AM
JohnnyG's Avatar
JohnnyG
I didn't get a chance to check the washer jets yet, how would I know they are the "heated ones".....anyone have a pic of the underside of the hood with heated washers??? Can you order JUST the heated seats???
Thanks!!!
Old Dec 17, 2007 | 06:56 AM
cristo's Avatar
cristo
Alliance Member
Thanks!!!
Yes
Old Dec 17, 2007 | 08:23 AM
Eric_Rowland
And thus the problem is revealed. Never underestimate the first question from tech support - "Is it plugged in?"
Yep heated seats were a seperate option, it was another $30 for heated jets/mirrors.
molala
Oct 2, 2015 01:53 PM
Norton70
Sep 7, 2015 05:06 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
