My car is bleeding
Old Dec 8, 2007 | 05:32 PM
davavd's Avatar
davavd
My car is bleeding
I haven't driven my car all day, but just backed it up a couple of feet, so I could pull down the attic stair and get the christmas tree stand. There is a puddle (only about a tablespoon) of dark green liquid on the floor. What fluids might be dark green and what does it mean if it loses some? As luck would have it, I'm scheduled for a +/-30K oil change on Wednesday.
Old Dec 8, 2007 | 05:53 PM
Motor On's Avatar
Motor On
Sounds like coolant. Where abouts isthe leak? I'm betting it's the thermostat at themoment.
Old Dec 9, 2007 | 05:29 AM
davavd's Avatar
davavd
Thanks, Motor On. The drip is just back of the plastic on the front, about 4" to the passenger side of dead center. The level of coolant in the tank is below "MIN", just barely covering the bottom of the tank . I'm guessing it's not good to drive like this . I'm also guessing that the almost full bottle of Prestone Antifreeze/Coolant (indeterminate age) I found in the shop is NOT what I need to add. What do I need to add? The Owner's Manual is appallingly uninformative - "your Mini Dealer knows"
Old Dec 9, 2007 | 05:41 AM
lilruffcat's Avatar
lilruffcat
I know the dealerships have mini cooper coolant.. It may be worth giving them a call.
Old Dec 9, 2007 | 05:49 AM
davavd's Avatar
davavd
Not on Sunday, and they are 75 miles away. Research around here indicates that BMW coolant is the thing to use. However, it just needs to get me to work and back twice (52 miles roundtrip) and then to the dealership. Wouldn't any coolant be OK for that, provided I tell the dealership what I did?
Old Dec 9, 2007 | 07:25 AM
ScottRiqui's Avatar
ScottRiqui
If you just need to to make it a few hundred miles, keeping the reservoir topped off with distilled water would work fine. No worries about incompatibility with your current coolant, and the dealer is almost certainly going to drain everything and refill with fresh coolant after fixing the leak, anyway.
Old Dec 9, 2007 | 10:52 AM
davavd's Avatar
davavd
Thanks, Scott.
Old Dec 9, 2007 | 10:56 AM
ScottRiqui's Avatar
ScottRiqui
You're welcome - let us know if it ends up being the typical thermostat leak or something else.
Old Dec 13, 2007 | 08:30 AM
davavd's Avatar
davavd
The SA at Brian Harris Mini in Baton Rouge said there is a seal leaking at the water pump. They didn't have a water pump, so they ordered one and sent me home in a Honda Accord.
Old Dec 20, 2007 | 12:07 PM
davavd's Avatar
davavd
Got the car back yesterday (a week at the dealer) w/ new water pump, coolant, and the scheduled oil change. Once again, driving is fun.
eliseo1981
Jan 28, 2021 02:45 PM
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Gipper
Aug 8, 2015 05:39 AM
PatrikKN
Aug 5, 2015 09:10 PM
