Engine wants to die whenever I turn quickly??
Old Nov 28, 2007 | 03:11 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Here it is:
whenever I take a "sporty" turn, the engine wants to stall (no power) just like it does when the DSC shuts the engine... but the DSC is turned off...
In straight line, it is all good...
A really annoying problem...
Anyone got an idea??
Old Nov 29, 2007 | 12:49 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Which direction? Is there enough oil in the engine? My only thought is that there is not enough oil for the pick up when you take a hard right turn. But then again, you would have to have only a few quarts to get that to happen - the oil pickup is very low in the pan. Judging from your mods, you are a person who cares for cars and checks oil every week, so I'm sorry I can't think of anything els.e.
Old Nov 29, 2007 | 04:10 AM
D3m0N's Avatar
D3m0N
Could it be a failing electric steering pump adding resistance to the alt?
I know if I sit in the garage and turn hard right or left the RPM drops about 100 to 200 points
Old Nov 29, 2007 | 06:25 AM
DarkMiniCooperS
Oil is fine. thanks for pointing this out.
Power steering pump. I know the power steering pump is not drawing power from the engine via a pulley, but if it's drawing too much power, will this make the engine want to stall??
Thanks for any help! I am completely lost and still believe it will be fixed with a cheap solution... Just ordered DT BBK and that annoying problem showed up the next day. :-(
Old Nov 29, 2007 | 09:50 AM
Eric_Rowland's Avatar
Eric_Rowland
Low on gas??
Can't think of anything else that would cause it.
When you say 'sporty' does that mean wheels are losing traction? You've got LSD, so it's not wheelspin...
Old Nov 29, 2007 | 09:58 AM
DarkMiniCooperS
Originally Posted by Eric_Rowland
Low on gas??
The first time it happened, I was low on gas, but I filled it yesterday morning and it's still happening...?? :impatient
Yeah I have a LSD, but the engine seems to cut itself before any sign of wheelspin or LSD activates...
This problem is driving me nuts! lol This afternoon, my garage will change the fuel pump's seals because the passenger's side has some leaks signs... I don;t know it this has a link to my issue but I'll see...
Feel free to give any opinion or tip that would help me!!
Thanks !!
Old Nov 30, 2007 | 08:26 AM
LEPRACHAUN's Avatar
LEPRACHAUN
This is an old idea. Have heard quite a while ago ( decades ) of a bad coil. They at least used to be oil filled. There were cases where in turning a corner all oil sloshing to one side would basically disrupt the coils output. Although this was said to lead to having to restart the car. Don't know about the MINIs coil or how to check it though.
Old Dec 8, 2007 | 07:14 PM
DarkMiniCooperS
Problem solved...
The fuel pump's gasket (seal) was really bad... Got a new one and it's all good now...
Thanks everyone for helping!!
Old Dec 8, 2007 | 08:18 PM
Motor On's Avatar
Motor On
Originally Posted by DarkMiniCooperS
Problem solved...
Glad to hear you got it fixed, I was just about to point you in the direction of a guy having this problem at Sebring last summer.
Old Dec 8, 2007 | 08:24 PM
Eric_Rowland
Problem solved...
Good deal - how involved was the fix?
Old Dec 10, 2007 | 07:46 PM
DarkMiniCooperS
What was his problem?? I would like to know if you remember.
The seal was $15 from a MINI dealer. My garage charged me 1 hour of labor, but this includes the troubleshooting and the installation of the seal... Honestly, I think it is a great deal since they spent 2 hours looking at everything, from the power steering system to the DSC sensors... Props to Arthur @ Euro Auto Tuning for the great service!
09R56
Nov 16, 2022 10:49 AM
scottrn
Aug 22, 2015 07:26 PM
xpunisherx
Aug 10, 2015 10:50 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
kwijmbo
Aug 5, 2015 09:00 PM
