New Rotors @ 40K Miles?
Old Dec 5, 2007 | 06:26 PM
  #26
ToBFree's Avatar
ToBFree
I didn't want my old rotors. I think Chad uses them to hold his vendor tent posts to the ground. While I could have installed them myself, I preferred to sit and watch Chad do it and talk about MINIs, etc. It was fun to be able to learn a few things from someone who knew what he was doing.
Old Dec 6, 2007 | 11:13 AM
  #27
HotRodPilot's Avatar
HotRodPilot
Originally Posted by HotRodPilot
I believe my brakes have warped after 3,000 miles with no auto x's or track days. Can powerslot rotors be turned?
Well I'm not so sure they are warped, I guess it could be deposits on the rotors. Is there any way to correct the problem before buying new rotors
Old Dec 6, 2007 | 11:27 AM
  #28
BlimeyCabrio's Avatar
BlimeyCabrio
Rich - What specific appearance / symptoms / problems are you having that make you think there's something wrong?
Old Dec 6, 2007 | 11:32 AM
  #29
HotRodPilot
Steering wheel shudder when slowing down from over 20mph with at least 50% brake pedal pressure.
I have Hawk HPS pads all around and powerslot front rotors. Pads have 2 track days and a dragon weekend on them, the powerslot rotors have a day at the dragon on them.
Old Dec 6, 2007 | 11:44 AM
  #30
BlimeyCabrio
Hmmm... if you visually inspect the rotors, how do they look? see any deposits? See any uneven wear? If you drag a finger radially across the rotor (both sides) do you feel any "ridgy-ness" or is it smooth? Did this just start after 3,000 miles on the rotors?
Old Dec 6, 2007 | 12:07 PM
  #31
HotRodPilot
No deposits to be seen
Not that I'm able to see. The rotor surface looks the same all the way around the rotor.
I haven't had my wheels off yet to be able to run fingers all the way around on both sides, however I've run my finger along 3-6" parts on the outside of the rotor and it felt smooth.
Yep, I had the rotors put on at MINIs on the Dragon in May, did a day driving the Dragon, and managed to get about 700 miles on them before I deployed a couple of weeks later. I started to notice the vibration a week after I got the car back from the body shop on my way to NY.
I need to go have a leaking thermostat replaced by Dan as soon as I can get a chance to drive up, so I'll have him take a look. I was hoping that is the rotors are warped then powerslots can be turned, and if it's pad deposits I was hoping that somehow the deposits can be removed at a low cost. I'm hurtin' for money right now:impatient
Toolman
Jan 20, 2016 06:50 AM
aldito2
Nov 25, 2015 09:33 PM
squawSkiBum
Oct 2, 2015 09:21 AM
ltjpunk7
Sep 6, 2015 07:32 AM
thebordella
Aug 31, 2015 01:37 PM
