Cold temp PS pump noise?
Old Nov 19, 2007 | 10:09 PM
fleance's Avatar
fleance
Drove the MCS in sub freezing temps the other day for the first time and I noticed a noise while turning with a cold engine bay. It only seemed to appear under short radius turns and sounded very much like other cars I've owned when the steering is held against the fully left/right lock position and the pump is straining.
My question is: Is this worth attempting to recreate for the dealership while still under warrenty? I've got 2 winters left to do it and it'd be a pain to get an appointment, in cold weather and deliver the car with a cold engine to reproduce it reliably.
If it's just a noise I can live with it, no big deal, but if it's an idication I might have to replace the PS pump I'd rather get it done early on under warrenty.
TIA,
-/flea
Old Nov 20, 2007 | 05:28 AM
pcnorton's Avatar
pcnorton
TIA,
-/flea
You answer your own question right here. Get it checked. My pump is out and I have a quote of $1400 to R&R at the Mini dealership.
SO is not getting it checked under warranty gamble worth it to you?
Paul
Old Nov 20, 2007 | 08:14 AM
fentos's Avatar
fentos
My pump went out last weekend. New pump came yesterday (to the tune of $542) and I will be replacing it tomorrow myself.
I'd suggest atleast getting it checked while you can. These pumps don't seem to last very long. Mine went out with NO notice.
Old Nov 20, 2007 | 10:10 AM
pcnorton's Avatar
pcnorton
How's you cooling fan? I'll be doing mine in a week or so. Tried to Remove the pump Sunday but I couldn't find the other bolts to remove. 2 for the PS fan were easy. Then there was another easy one (all on the bottom of the car and easy to see)...But then I could see the other bolts to remove. Have a friend with a lift so it will be alot easier on my next attempt.
Paul
Old Nov 22, 2007 | 04:57 AM
fentos's Avatar
fentos
I checked the cooling fan and it was ok. Of course it comes off pretty easy with those two bolts.
I used these instructions to do mine:
https://www.northamericanmotoring.co...0&postcount=10
Old Nov 22, 2007 | 08:43 AM
pcnorton's Avatar
pcnorton
Sweet. The picture from the rear for the bolt I couldn't see. The bentley wasn't as clear.
Paul
Melvinyip
Apr 17, 2020 09:28 AM
TREX
Nov 2, 2019 07:31 PM
Cereall
Sep 5, 2019 06:05 PM
dscott90000
Aug 23, 2015 08:21 PM
damncajun
Aug 17, 2015 08:25 PM
