anyone know how to troubleshoot the obd code p0444--evaporative emission system???
Old Oct 31, 2007 | 10:34 PM
aqt's Avatar
aqt
had just used an obd resetter on my mini..a generic one..what should i do if it tells something about the "evaporative emission system purge control valve circuit open"? sorry,im not familiar with these..where can i find this valve?have an 02mc
Old Nov 1, 2007 | 04:34 AM
03BRG's Avatar
03BRG
Start with the gas cap, is it tight?
Old Nov 1, 2007 | 01:37 PM
hemiheaded18's Avatar
hemiheaded18
+1
I see this code a lot. I just saw it again today on a guy's Ford. It was loose.
Old Nov 2, 2007 | 09:56 AM
Ancient Mariner's Avatar
Ancient Mariner
The valve is the black plastic doohickey on the left front side (as you face it) of the engine. Has a hard plastic hose going in the bottom, one coming out the top. It's about the size of a big cigar. It's part of the fuel system pressurization/vapor control process, along with a pump (not the fuel pump) and a charcoal canister under the rear wheel lining. If tightening the gas cap doesn't fix it, the other common cause on older mini's is the charcoal canister may have a crack and won't hold vacuum.
Old Nov 5, 2007 | 11:43 PM
aqt's Avatar
aqt
tnx for the info....have seen the canister,and saw a wire/socket down there unplugged..will try to check if there won't be any problem re this code..many thanks..
AdrenaliNate
Nov 4, 2015 07:26 PM
portedbuckle
Sep 11, 2015 07:02 AM
one73ronin
Aug 19, 2015 12:36 PM
