Car not starting, 3 DTC Codes...
Old Oct 30, 2007 | 08:19 AM
Guest's Avatar
Guest
So I went out this morning to head to work and my car won't start. It sort of sputtered a bit like it was going to catch, so I stopped cranking in hopes that if I tried again it would, nothing. Now it's just cranking, doesn't seem to want to catch at all.
The 3 DTC's I got were
P0340 - Camshaft Position Sensor 'A' Circuit.
P0031 H02S BANK 1 SEN 1
P0037 HO2S Heater Control Circuit Low
Any ideas? Last night we drained the oil and installed an oil pressure and oil temp gauge, but I can't see what that has to do with any of this. It seems unusual that the Cam Position sensor would just die, my car only has 20,000 miles on it. Also from what i've been reading the car typically will still start when they go out.
I cleared all the codes and cranked it again to see if those were old codes and it threw them all again. It's got to be something linked to all 3 sensors... fuse maybe? Relay?
Old Oct 30, 2007 | 10:29 AM
Guest's Avatar
Guest
Fixed it... It was an engine electronics fuse. The starter power wire hit the heat shield or something.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Lt. Dan
Aug 10, 2015 12:46 PM
veevsato
Aug 5, 2015 04:42 AM
