Speed Sensor Problem
Old Sep 6, 2010 | 09:13 AM
  #26
trippyloaf's Avatar
trippyloaf
I had the same problem removing the wheel speed sensor. One came out fine, the other (driver's side) was stuck. After trying to twist/pry it out, the top of the sensor sheared off. I did not want to tap it down into the wheel bearing hub because of the associated work involved removing that so I drilled a pilot hole into the sensor, screwed a wood screw into the sensor, shot some PB onto the sensor (wait), and then used a hammer to pry it out like a nail. Worked like a charm.
Old Sep 6, 2010 | 09:36 AM
  #27
nbio's Avatar
nbio
holy thread revival! but yes, I just ended up drilling the whole sensor out.
Old Mar 14, 2011 | 02:05 PM
  #28
ohammero's Avatar
ohammero
I have had the same problem. Went to the local BMW dealer and they told me wich one to replace. The problem is still there, I hate cars that don't work...
Are there anyone here who know if the ABS sensor is the same on a 2001 and a 2002?
Old May 7, 2011 | 06:44 AM
  #29
ajv915's Avatar
ajv915
So I understand that the ABS, DSC, TMPS trifecta is most likely the wheel speed sensor. However, I was wondering if DSC = ASC ? As the manual says they are different things. Would the fix still be the same (Clean the sensor) or does ASC mean I need a new module ?
Old May 7, 2011 | 09:57 AM
  #30
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've never seen cleaning the sensor fix any ABS issue, that would only work if a piece of metal was stuck to the tip of the sensor.
DSC and ASC are only different in that DSC has more sensors and operation. But the ABS part of the car is the same either way.
If you have an ABS, and or DSC/ASC light on you need to have someone with a computer that can read those codes check it out and diagnosis from there.
Old Aug 20, 2011 | 09:53 AM
  #31
b0rkman's Avatar
b0rkman
Installing new sensor
Ok, had same prob getting old one out, screw method with pry bar did trick. But now how do I get the new one in? Will a petroleum based lube do the trick?
Old Aug 22, 2011 | 02:16 PM
  #32
b0rkman's Avatar
b0rkman
Got old one out and new one in. Seemed to work fine this weekend but started intermittently pulsing when apply different degrees of braking pressure. Also at different speeds.
Any thoughts on what the problem may be - faulty sensor?
No fault lights are tripping...
Old Dec 18, 2013 | 02:31 PM
  #33
dez's Avatar
dez
I have this same problem on my wife's mini. The stealership wants $400 to change it...
I have the part on order. My question is how safe is it for my wife to continue to drive with the faulty sensor?
Old Dec 18, 2013 | 02:58 PM
  #34
ScottRiqui's Avatar
ScottRiqui
There's nothing inherently unsafe, as long as she realizes that ABS and Stability Control won't work until the wheel speed sensor is fixed.
Old Dec 18, 2013 | 03:23 PM
  #35
dez's Avatar
dez
thanks for the reply
she realizes it... whether she changes her crazy driving habits is another story
Old Jan 3, 2014 | 07:57 AM
  #36
tonmilv's Avatar
tonmilv
had all three lights on, ABS, VTC, TP. went to prestige mini, NJ and they got me for $475 + tax ouch.
Old Jan 9, 2014 | 04:27 AM
  #37
JRhea's Avatar
JRhea
My passenger side sensor was frayed from rubbing the harmonic balancer. I bought a new one on eBay for $15. It didn't seem to fix the issue so I repaired the frayed sensor by soldering a new wire in. Now the light stay off for a few days and then on again....back and forth. For now they are keeping the airbag light company. I'll get it resolved one of these weekends.
Kimolaoha
Jul 5, 2023 01:04 PM
David.R53
Sep 1, 2015 06:49 PM
massmini03
Aug 12, 2015 11:19 AM
MES11
Aug 8, 2015 10:21 AM
